I'm running Windows 7 on an Asus U52 laptop. Whenever I mute using the mute button on the keyboard, the sound turns off. But when I try to unmute I cannot get any sound. The icon in the lower tool bar, all the information in the control panel, and every place I've checked shows that I should be unmuted. The only way to get sound back is to reboot the machine. Why is my unmute not working? Any ideas?
I had same problem with my asus laptop. i contacted to asus tech support and they have fixed my problem instantly. hope they will help you as well. for more information you can visit :
Tech Support For Asus
Sounds like a bad driver download the best driver for it from their site.
SOURCE: my asus g73jh has no sound\r\n the windows 7 64
GO TO THIS WEB AND DOWNLOAD THE FIX AUDIO DRIVE ON 7 64
http://support.asus.com/download/download.aspx?SLanguage=en-us
CHOSE WHAT MODEL OF AUDIO HAVE IF CREATIVE DOWNLOAD FIRST ONE IF REALTEK DOUNLOAD BOTH
SOURCE: where do I go to
Go to this link:http://support.asus.com/download/download.aspx?modelname=U52F&SLanguage=en-us
SOURCE: My asus eee pc will
Restart your computer..start tapping F8 quickly..if you reaches advance boot menu..there select repair my computer..then select the language..then enter your username and password if you use any..in recovery options you can try startup repair or system restore options..lastly if nothing works then select the factory image restore which will take your computer to factory settings but delete everything
SOURCE: Hi! I've bought a brand new Asus laptop and
Hi maruthusumi I hope this helps. If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Resource file C_SpURsDll not found - SYSTEM FILE CORRUPTION
If in doubt about any aspect of this advice, please feel free to add a Comment or Clarification to this Question. If so, please include information about the model and specification of your computer. Doing so helps us makes faster, more accurate and more assured Remote Diagnostics leading to better quality and more useful Advice, Answers, Guidelines , How-Tos and Solutions.
You also don't say how you installed the Applications, particularly if any of them were downloaded from the internet. If so, the download might have been, corrupt, incomplete or malware infected. Another potential source of corruption to System Files are corrupt, incomplete Updates downloads or interrupted Updates configuration processes.
It would appear that there has been some corruption to your Windows 7 64-Bit System Files.
The first issue to consider is whether all the Applications installed are 64 Bit or 64 Bit compatible. If not, uninstall the applications, but first you have to resolve the problem.
I suggest:
Start > All Programs > Accessories > System Tools > System Restore > Restore my computer to an earlier time > select a highlighted date on the calendar to the left and an event in the event schedule to the right that both precede the error > Restore > Restart PC.
You can only safely install MS Office from a genuine MS Office Disc or download it from an Authorised Access, Multi-user Licensed ISO File on an office server. FTP Client Applications are the same. Safe, reputable, reliable online download sources abound, such as www.acebit.com.
If System Restore does not clear the problem and any applications were downloaded from the web, try running antivirus and antispyware scans to purge any infection found.
If none of the above works you might have to Restore to Factory Default Settings and install your Applications carefully again.
Thanks for using FixYa.
SOURCE: How do I reboot my ASUS EEE PC 701SD 7" 0.9 GHz
To start the systemrecovery:
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer.Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
