Question about Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw
My 345 chainsaw bogs down when it hits wood
My chainsaw starts right up idles fine but it doesn't seem to rev as high and as soon as it hits wood it bogs down and just wont cut for ****. I have changed fuel filter air filter and spark plug.
    Problem Solver:
  • 16 Answers
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Posted on Jan 19, 2009
    Problem Solver:
  • 3 Answers
Firefishin is right I have a Stihl 028 Woodboss chain saw and of had the same problem until i touch the low idle screw it sloved my problem.
Posted on Jun 05, 2009
Chokes and Dies when cutting
Adjust the choke or carburetor. In case your chainsaw stalls when the engine is idling, ensure that the choke is set properly. To do so, first try releasing it to adjust it, and then move the plate and tighten all screws once again. To loosen any grit, spray carburetor cleaner spray on the choke's shaft. The carburetor may also need to be adjusted; consult your owner's manual which will guide you on resetting the idle mix screw.
Mar 13, 2014 | Ryobi 940968018 C4620 Label
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Bogs out
First check the air cleaner. Clean or replace it. You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw usually on the left or right side of the carburetor on the outside of the housing. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn. After adjusting the mixture it might be necessary to readjust the idle speed.
Sep 12, 2009 | Garden
Loses power when trying to cut wood
Check the muffler screens first. Then the spark plug. If not the case, then adjust the High setting on your carb. Prolly starving for fuel under engine load. If it is still a problem, Pull the carb and clean it.
Apr 27, 2009 | Homelite ZR10926 16" Chain Saw
McCulloch chain saw wont stay running after it warms up. I go to cut wood it start to bog down if i let go of the button it idles fine
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
yes
no
Mar 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Craftsman 16'' chainsaw, start with very high rpm, how to adjust ?
The H is for when your cutting,it keeps the saw from stalling. The L, is for the saw when at Idle. When the L ,is adjusted right, the saw should stay running ,and the chain should not move ,that is with the break in the off position. The H screw,should be adjusted if the saw bogs down when rev ed up. A good starting point for theses screws would be a turn and one half out.
Jan 19, 2009 | Garden
Poor performance at hi revs on poulan 3314
Try turning the high idle screw out 1/8 to 1/4 turn refer to your manuel for the location of this screw.
Dec 10, 2008 | Poulan Garden
Idle is off??
hi leobowdy
disassembly the carb and carefully clean it.Check the air filter,the fuel line and fuel filter,check the needle,lever,small spring and the screen filter from the carb.Check the sparkplug.
high speed H=2 turns,low speed L=2 1/2 turns,adjust T
When chain saw starts adjust H,L and T accordingly.
cheers savumihai71.
Nov 22, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
2,929 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
