Question about Mitsubishi WT-46807 46" Rear Projection Television
WT-46807 Red convergence is distorted, in an arch at the bottom.
The red convergence is distorted, in an arch at the bottom. The red convergence does not move when i try to align it with the remote. The blue and green guns are fine, and when I block the red gun, the picture looks great (except the funny colors from the lack of red) I consider myself good with electronics, however have never worked on tv's. I don't have a schematic to try to find the IC's that drive the red convergence. Are they on the pwb on the back of the CRT? Or are they on one of the other mainboard PWBs? Is there any way that you can help me locate these IC's and possibly a part number so that I can try to find replacement parts? If it would help, I can post a picture of what the problem looks like on the screen. Thank you in advance!
Brian
  • Mitsubishi Master
  • 8,617 Answers
Yes your model is the V17 chassis mitsubishi. The Convergence Ics are located on the center board. you will need two STK392-570 convergence ICs. You can get replacement ICs at the following link and they provide free installation instructions. They are located on the backside of the wide heat sink with the fins on it on the center board
http://servicemanuals.vstore.ca/
Posted on Jan 19, 2009
How do I replace the fuses on a WT-46807 that protect the convergence circuit?
There are no fuses going to the convergence board, the converegnce IC needs replaced.
Aug 08, 2011 | Mitsubishi WT-46807 46" Rear Projection...
I have encountered convergence problems as well with my older Mitsubishi WT-46807 and would be appreciative if I could get repair instructions. My email address is djmerrill77@yahoo.com Thanks.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 16, 2011 | Mitsubishi WT-46807 46" Rear Projection...
Picture is blurred by tri-colored image (yellow, red, green or blue)
The tv have a problems known as convergence problems.The tv convergence board are dead.These parts on the tv convergence board must have it 2 STK convergence ICS and some or all it resistors replaced,to solved convergence problem.U know basic soldering,have all the tools?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to do the repair it ur self.The shop will cost u $300-350 for parts and labors.
Aug 25, 2010 | Mitsubishi WT-46807 46" Rear Projection...
My picture is blurry, re-setting the convergance helps
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Bowed picture colors off
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
Nov 02, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Can't set red convergence on 65" Hitachi
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Dec 24, 2008 | Hitachi Director's Series 65XWX20B 65"...
Mitsubishi WT-46807 46 in picture bends and the blue red and white all seperates
intermittent convergence fail. suggest re-soldering the 2 convergence output ICs on the middle power board. they are the 2 large devices located on the largest heat-sink on the middle board(looking at from back) once you re-solder them as long as the aren't faulty internally you should be all set.
Mar 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Convergence?
From what i see in these posts most say its the IC ship to replace i will get one for my 46807 also but dont know where yet .
also i seen that if that dont fix it then there is a few resistor's to resolder someplace dont know where either..but i can make the repairs myself im handy CROSS fingers ..:)
Nov 24, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Magnavox 51mp392h
One of your convergence IC's has burned out or cracked loose and needs to be replaced or resoldered. This should be done by someone experienced in repairing and realigning convergence circuits.
Jul 11, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
166 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
