Alba lcd tv with dvd - model AELKDVD1988 - now saying no signal when trying to load dvd - was working yesterday ok
Was working yesterday - but now when load dvd not spinning and saying no signal tv working fine with cable connection
Highdefjeff
  • 124 Answers
SOURCE: Visco LCD TV VSC-32V3 32
After connecting the cable to the TV, you should scan for channels. With the built-in cable QAM tuner, you should be fine with a scan for channels.
Try another TV to make sure that cable broadcasting is coming in...is there a set-top cable box involved?
Posted on Apr 08, 2008
SOURCE: Insignia LCD HD tv with "No Signal/VGA input"
Your Television need to be reset. Take the back off carefully, locate your picture lamp, somewhere in that area should be your reset button. Your television needs to be powered on, so be very carefull not to touch anything other than the reset button, hold the button in until your TV goes blank, then release and put your cover back on. That's it, your TV should be back to normal. You might have to run your setup again.
Posted on Apr 18, 2008
cormoncable
  • 51 Answers
SOURCE: my TV says NO SIGNAL on tuner...
yes, you may be lucky to just to burnt one of the source/input mode try switching them.
for example use a video cable instead a coax if you still dont get a signal that means the picture uotput board is damage by the storm.
Posted on Aug 15, 2009
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
tvservice306
  • 458 Answers
SOURCE: Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Posted on Jan 01, 2010
Testimonial: "Thanks for the info! Very helpful!"
I have a Magnavox 15MF400T/37 LCD TV operating with a cabel connection. As of yesterday it has no functions but when I turn it on I get a message that says Attention No Signal. I have checked the cable...
Some of the newer TV's dont turn on if there is no input signal. Try a DVD player and see if that works. If it does, then the issue is most likely with the cable jack on the TV, which may need to be replaced..
Jul 21, 2008 | Televison & Video
Our tv, model 42hp25bat, has been running on our cable input for the past year. All of a sudden the tv input setting says "no signal". The tv works for our DVD player on HDMI setting. We...
the signal input on the cable connection to to your tv (inside your tv) is broken, and possibly needs to be replaced. Possibly few capasitors or other parts might need to be replaced. or the whole signal board.
Apr 17, 2008 | Televison & Video
Hi i have a 19 inch alba tv dvd combo in dvd mode the tv says no signal dvd is just dead tv works fine says call argos
The player has failed, it is not a product that is really repaired due to the low cost of a new one, I would just buy a stand alone player and right this off.
Nov 25, 2016 | Alba Televison & Video
Alba 15"LCD TV and DVD Player will not play DVD's, it sounds as though the disc is turning. It will play music CD's
Laser Pickup Unit [Lase head] is weak. There is no repair to this part. Replacement only can be done. Contact any service technician. To replace it, you have to disassemble and take out the disc loading mechanism from the set.
Electro help
Mar 01, 2015 | Alba Televison & Video
My Alba TV , when scanning for channels ,says no signal, check antannae, which i have by connecting a different tv, its working good , but my tv not showing any channels when even using first time ins
Check and replace the tuner inside the TV. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 01, 2014 | Alba LDVD1538WDCH LCD TV
Why has my Alba TV Screen say no Sygnal
how is youre cable connected to the 1-tv 2-cd/dvd player 3-amplifier, coming from satelitte..If you watch a dvd, somtimes you half to push the tv.video button on the dvd remote control just once to allow the tv cable signal to pass to the tv. each time you watch a dvd it blocks the tv signal. this is normally true unless you have a special wiring configuration
Aug 30, 2014 | Albatron Computers & Internet
I have a beko 37 inch hd ready tv i recently go the sky hd box . my tv only has one hdmi port and i also have a samsung blu ray dvd player which only has a hdmi connection i got a switcher box for the hdmi...
It is possible the hdmi cable that you are using is faulty. The reason I say this is because you have multiple signals that pass through a hdmi cable (19 pins in it means 19 wires to carry signals). The more the cable gets moved and bent, you increase the chances of creating a short or re-connecting a short if moved from one tv to another. This is the best case scenario as it is easier to replace the cable and less costly. Since you already connected the the dvd directly to the tv, and I am presuming that you have working devices running through the switch and you can eliminate that as the problem. If you do not have working devices on your switch or directly into your tv, and you have tried multiple hdmi cable and still nothing, the hdmi connector on your tv is probably bad and that would be the worse case scenario.
Nov 03, 2013 | Philips Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
