Question about Mitsubishi WD-57733 57" HDTV
While Mitsubishi is off, have spots between inter-projector screen and outer
This is non-electronic. Spots are inside the screen. Can these be removed by removing the outer shell?
  • Mitsubishi Master
  • 8,617 Answers
Yes you can disassemble the front screen assembly to clean any spots dont use windex or streaking will result just a damp soft cloth then dry
Posted on Jan 02, 2013
techman
  • 3130 Answers
SOURCE: Mitsubishi Projection TV Model TS 4573 not TS 4545
No if the problem is the screen, you will need to replace the entire screen assembly. some screens come in two parts. The inside of the screen is called the freznal lens, the outside of the screen is called the lenticular lens. Good Luck
Posted on Jun 05, 2007
  • 115 Answers
SOURCE: Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Posted on Sep 28, 2009
  • 46 Answers
SOURCE: Mitsubishi dlp tv WD65733 has white spots, like
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Posted on Mar 27, 2010
SOURCE: bugs are inside tv seen on inside of screen, how
How do I remove the screen to remove bugs?
Posted on May 25, 2010
CaptainHawk1
  • 345 Answers
SOURCE: My mitsubishi 65-inch dlp tv
It's either mirror hinge fatigue or dust on the inside.
Mirror hinge fatigue can be fixed by putting a solid color picture (white or gray works best from what I understand) on the display and letting it sit for 20 minutes.
If it's dust, someone is going to have to go in there and clean it out.
Also could be a defective micromirror device.
Try the first suggestion and if it doesn't work, you're going to need a technician to take a look at it.
Posted on Nov 23, 2010
I have a NEC projector in my class but projects white spots on the screen which are multiplying day by day. Has anybody solved this problem ???
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 07, 2014 | NEC NP200 Projector
IMAGE PROBLEMS I HAVE LINES AND BLACK SPOTS ALL OVER DISPLAY
Sounds like multiple problems the spots are the dlp/dmd needs replaced the lines are a bad cable or a loose wire inside. Here is a similar model video http://www.youtube.com/watch?v=775YOs-aOPc&feature=share&list=UU_Iacxxa-E63l6FhQjkcH8A
Nov 10, 2013 | Mitsubishi EX240U Projector
I have white spots on my image from my projector SHARP XR-55X?
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD200
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 05, 2013 | SHARP ELECTRONICS CORP PROJECTOR, SHARP...
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
White spots Mitsubishi EX240U
This is a dmd chip going bad. Here is the replacement on a very similar model. You would need to verify your chip number to be sure. Love to know if it is the same as the 250 and it probably is. http://youtu.be/775YOs-aOPc
Nov 15, 2012 | Mitsubishi EX240U Projector
Dust inside the lens on a mitsubishi projector
if you have white or black spots its dlp chip. Here is a video of disassembly of a similar machine. http://www.youtube.com/watch?v=775YOs-aOPc&feature=share&list=UU_Iacxxa-E63l6FhQjkcH8A
Oct 20, 2012 | Mitsubishi HC7000 LCD Projector
LCD projector spots showing up on the screen
there are light filters behind each lcd panel that determine the color of light going through it. because of excessive heat and dust, the filter tends to burn and cause discoloration in the image. if the image is bluish (cyan), the red filter is burning. if it's yellow, the blue is burning. if it's purplish (magenta), the green is burning. the filters will need to be replaced. unfortunately, many companies don't sell individual parts of the optical engine, so the entire engine might need to be replaced.
Aug 20, 2009 | Epson EMP S1 Multimedia Projector
Yellowing spots on 52 inch LCD Mitsubishi display
have the store fix it you need a tech that has the right equipment to fix that. Since you say you replaced the lamp I assume you mean a LCD micro projector not an LCD Flat panel. There is a piece of equipment that a tech should have that can be plugged into the TVs circuit board and it can fix the spots with an electric pulse. I have seen in done on micro projectors in the store that i work by our techs. So my advise is have the store fix it before your warranty runs out.
Mar 24, 2009 | Mitsubishi LT-52133 52 in. LCD HDTV
Mitsubishi WD-57733 57" HDTV Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
