Question about Bosch HGS3052U Gas Kitchen Range
The electric power went out on my Bosch gas range. The gas still comes on. Is there a reset button, fuse or other way to self fix on New Year's Day? Thanks.
The electric power went out on my Bosch gas range. The gas still comes on for the stove top. Is there a reset button, fuse or other way to self fix on New Year's Day? Thanks.
5 Suggested Answers
  • 3 Answers
SOURCE: MY BOSCH ELECTRIC RANGE NOTHING WORKS, GET POWER NO HEAT
u may need to set ur clock to manual operation. check instructions if u hav them
Posted on Feb 06, 2009
  • 5 Answers
SOURCE: I have a Bosch gas range Model: HGS346UC 0/1.
If the cooker has a digital clock it needs to be reset to manual or until 00.00 appears on display . To do this hold " - " button until the 00.00 is displayed .
Then press and hold the "+" and "-" buttons in both together at the same time until all settings have been cancelled . Try the oven now and it should come on.
Posted on Mar 26, 2010
bbl242003
  • 1637 Answers
SOURCE: I have a Bosch HEI7282U range. Went through self
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut
Posted on Jan 31, 2011
intower18
  • 957 Answers
SOURCE: We had a bad storm
I would suggest to unplug the power cord for 10 seconds then plug back in.
Thanks.
Posted on Sep 06, 2011
Hi, My oven stopped working after using the self clean fuction. A repairman came to look at it and said I needed a new thermal sensor/fuse. He didn't have the part and has to come back. He reset t
Dont think there is a reset button. He shorted out the safety in order to unlock your oven. He did the right thing and you should wait until he returns with the proper safety thermal fuse
Apr 11, 2013 | KitchenAid KGSA906P Gas Kitchen Range
After self clean oven panel went black
Sometimes these can be fixed by unplugging it for a few minutes and plugging back in. I am assuming this is a gas top and electric oven. Verify the incoming voltage at the back of the range (not at the receptive but where it comes into the back of the range. Disconnect the plug before taking off the rear access cover and verify all the connections are tight before plugging it back in. Set volts to AC on your meter and check power between neutral and line (hot wire usually black). If this range uses 220 volts then check between the 2 lines (usually red and black). If the voltage is 120 or 220 respectively then you may have a fuse that blew (sometimes it is a fusible link in one of the power feeds) or a board.
Apr 05, 2017 | KitchenAid Kitchen Aid 30 In. Stainless...
Maytag gas range has no electrical power
These ovens are fitted with a 'wax' thermal fuse. Sounds like yours has blown buddy. Unfortunately you'll have to contact a Maytag dealer for help with replacing the part... shouldn't be expensive though... Hope that helps.
Oct 10, 2012 | Kitchen Ranges
I have a Bosch HEI7282U range. Went through self clean cycle, oven cooled down but oven door will not open. Put through another self clean, door still does not open. Cut power at circut breaker for over 5...
- Secure lock nut
Jan 31, 2011 | Bosch HEI7282 Electric Kitchen Range
We self cleaned our Bosch oven yesterday. Now the
I would check the following because during a self cleaning cycle a oven gets very hot and draws alot of power and this could of happened
Fuse/circuit breaker
Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker. Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Nov 23, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Clock went out and now have a loud clicking sound even with electricty turn off.
Checked the fuse box and found no issue, but switched it on and off. Then replugged in the oven but still got the clicking sounds. However after again repushing the clock reset buttons the clock came back on and clicking stopped.
Jun 01, 2009 | Bosch Kitchen Ranges
I used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. I unlocked the door and was able to open the oven door no problem. Later...
Hello Friends Creek.
Welcome to Fixya
You said, you used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. You then unlocked the door and was able to open the oven door no problem. Later on you went to use the oven, pushed the bake button and the lock light would flash. And you could not get past that to get the oven to come on.
You did the right thing to turn off the electricity and then turned it back on.
Did you wait 5 minutes before turning the power back on?Or just flick it off and on?
You said, the lock light still blinked.
But did it lockup again?
Please send me the model and year of your range.
Huuum
Oct 02, 2008 | Kitchen Ranges
Tappan 30 Series Range ignition system
no fuse/ with execption of trying to reset circuit breaker. perhaps the power tripped the breaker om the electrical panel, if the power supply is goos to the unit i would look to the spark module( it contorls all electronic ignition function
May 08, 2008 | Tappan TGF320 Gas Kitchen Range
All lights on the touch panel are flashing and a continous beeping sound
bosch 700 series range. So far unplugging the range and waiting several minutes to plug back in reset everything like rebooting a computer.
Dec 19, 2006 | Bosch HGS435UC Gas Kitchen Range
Bosch HGS3052U Gas Kitchen Range Logo
20 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
