Question about Mk Diamond Mk -470 7inch Tile Saw
Mk 470 tile saw motor needs brushes replaced where to purchase or can they be replaced
thabrain
  • 76 Answers
SOURCE: Blade replacement on mk-170 tile saw.
take a pair of good vise grips and hook onto blade tightly, slide uo against back braket. that will hold the blade from spinning while you remove the nut, try bumping your ratchet/ wrench w/ a rubber mallet or hammer. hope this helps
Posted on Nov 05, 2008
muttandjeff
  • 359 Answers
SOURCE: Water flows for cooling but saw does not rotate
check to see if the motor has overload reset button on it (red) usually the water is only pump portion of circuit and can run independent of motor circuit , if not check wiring to motor circuit
Posted on Dec 03, 2008
  • 29 Answers
SOURCE: Tile Saw Troubleshooting
if your blade is newer or even well used,one way to make it cut better is find a used brick or a piece of a concrete block and cut through them,what really works best is a carborundum stone that setters use to hone cut edges of tile,you can get 1 at any tile store or home depot for 5 bucks. another trick is to lightly pull up on the table towards end of cut, if they keep breaking at end of cut, and you have the gauge set simply flip tile up side down and start your cut then back it off flip it over and cut through. all saw cuts leave minor chips on cut edge, we always stone cuts. cutting a brick cleans debris off blade. MAKE SURE WATER IS PRESENT WHEN CUTTING
Posted on Mar 31, 2009
  • 55 Answers
SOURCE: I need the output shaft of this motor. It has the
You can order the parts you need from this website
http://www.mkdiamonddirect.com/category.sc;jsessionid=B8C66F8A4D5E422E3B401A634FBA7476.qscstrfrnt01?categoryId=99
Hope this is what you need
Posted on Dec 02, 2009
  • 55 Answers
SOURCE: I am trying to find an wiring diagram for a tile
Here is the website you need to find the manual and wiring diagram for your saw
Hope you find what you are looking for
http://www.mkdiamond.com/tile/saw_660.html
My MK-100 does nothing when I turn on the switch.
Check the brushes for the motor. very common problem in electric motors. It should look like a slotted head of a screw on the side by the motor. Only its plastic and about the size of a dime. After removing the brush, or magnet is what it actually is, replace it. Very cheap to replace and most hardware stores carry them. Hope that helps. Otherwise the switch is bad
Jun 27, 2012 | Mk Diamond MK - 170 Wet Cutting Tile Saw
My mk470 turns on and is really making a crazy sound but the blade wont turn
The motor on your tile saw is like a grinder, in the head is a set of gears, one on the armature and another at 90-degrees on the arbor. If the teeth on either or both gears are stripped off it will act and sound like you describe. When you move the motor or blade you are putting enough pressure on the gears that they touch enough to move the blade but it will never cut a tile. I have worked on these tile saws and have not been able to find parts for the motor to repair it. The entire motor is available on sites like www.ereplacementparts.com, part number 156428-R, but it's over $200 plus shipping.
Apr 06, 2012 | Mk Diamond Mk -470 7inch Tile Saw
My MK370 tile saw has a burning smell and it is making a slight banging noise every 7-9 seconds. The saw is cutting tile fine otherwise.
The problem could be bad brushes. Otherwise, you are probably burning the windings inside your motor. The slight banding noise could be an issue with the bearings in the motor itself. In which case you will soon be replacing the motor, so... we'll hope the brushes prove bad.
Assuming the motor has brushes, there will be 2 semi-large buttons on the motor (one on each side). They are screws. Remove them and beneath each one is a "brush". They should be long, hard, crack free, and smooth on the bottom where they touch the rotor. If not, then replace them. Almost all motors used for tools have brushes and some motors require disassembly of the motor itself to replace the brushes, but in your case, it should be an easy job. I can see one of the buttons on the Amazon picture.
:o)
Jun 03, 2011 | Mk Diamond 159943 MK370K 114Horsepower...
I have two 101's and both saws have a terrible wobbling. I have put new blades on both and no corrrection. I put the same blades on a 10" target and they boith cut perfectly....i am at a loss
well you might check the belt tension,you can tighten it by loosining the 4 nuts that hold motor then tighten the middle bolt in the back,that slides your motor forward,then retighten the 4 motor nuts.if saw sounds louder than normal, it probably needs new bearings
Nov 17, 2010 | Mk Diamond Mk Tile Saw Mk-101 Pro24 10in
Mar 31, 2009 | Mk Diamond MK - 1070 Tile Saw
Nov 20, 2008 | Mk Diamond MK - 770EXP
Tile saw helping tools
On most of the tile project you will need: tile nippers, 1/4", 1/8" and 3/16" spacers, grout sponge, mixing tub, mixer and various trowels.
Aug 27, 2008 | Mk Diamond MK 101Pro Tile Saw
Mk Diamond Mk -470 7inch Tile Saw Logo
140 people viewed this question
Top Mk Diamond Saws Experts
JonSnell Electronic
JonSnell Electronic
Regalo Tiles
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
