How can i order a thermostat for a fahrenheat fzl4004b wall heater
Therinnaiguy
  • 1420 Answers
SOURCE: Fahrenheat 4000 watt wall mounted heater shuts off and needs reset
Sounds like a bad temperature control switch. If it looks like it can be replaced, check with Johnstone or Grainger Supply company to match it up. Google it for their websites.
Posted on Dec 07, 2007
Buffalo12980
  • 625 Answers
SOURCE: fahrenheat wall unit
your on-off switch is faulty - need to replace it.
Posted on Dec 09, 2007
Buffalo12980
  • 625 Answers
SOURCE: Can someone please tell me what is the lowest temperature setting a Fahrenheat 3000 Watt Large Room Fan-Forced Wall Heater Model FZL3004 will turn on at ?
about the only way I can figure is to let the room get very cool and adjust the thermostat to its lowest setting. now turn on the unit. monitor the heat until the stat just opens. the thermostat bimetal will be closed and will open when the bimetal expands and opens its contacts. another way is to hitch up a chart recorder to measure temperature with its output connected to the heater. [too expensive for you or the DIY to accomplish]
Posted on Dec 14, 2007
hotuna
  • 288 Answers
SOURCE: Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Posted on Jan 09, 2008
Accurate Joe
  • 61 Answers
SOURCE: add line thermostat to fahrenheat space heater
Just disconnect the other thermostat. You can leave it there just disconnet the wires
Posted on Nov 30, 2008
My Fahrenheat baseboard strip heater is a 1996 model, 120 volts. It only works for one thermostat cycle. The thermostat points open slowly and arc as they open. The points will not reseat to supply any...
Why not get a 24 volt definite purpose contactor and connect it to power?
Use a transformer to open and close the contactor and then you can use a low voltage 2 wire el cheapo wall thermostat to turn on the heater?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 01, 2010 | Fahrenheat Electric Convector Baseboard...
Thermostat for Fahrenheat 5000Watt Ceiling mount heater
You could do it. It would mean serious wiring though and you should use the factory thermostat because it is designed to operate on 240 Volts. Or you could use a remote thermostat at low voltage to throw a relay in the heater and get it to come on. The manual has good diagrams on how it is wired and it would not be too hard to do. IT would operate just like the outside unit on an HVAC system .
Oct 26, 2017 | Fahrenheat Electric Convector Baseboard...
Electric space heater contactor won't stay latched
Jumpered the bimetal thermostat and everything worked smoothly. Tried to clean contacts in thermostat with no luck, so ordered a replacement. At least it was cheaper than the contactor.
Dec 07, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
Dec 13, 2007 | Fahrenheat FFH1615 Heater
Fahrenheat wall unit
Dec 07, 2007 | Fahrenheat ECP1524 Wall Mounted Panel...
How do I wire up my fahrenheat F25408 baseboar heater?
Baseboard heaters are easy to hitch up. You can have a wall mounted thermostat or an integral thermostat. The diagram I have is for the integral thermostat. Follow the diagram and it should work.
Nov 28, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
178 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
