Sky remote code for philips model number 40pfl7605h/12
  • 146 Answers
SOURCE: sky code for a goodmans gtvl19w17 hdv
Try this : Turn TV on, point remote away from TV, press TV button on your SKY remote...hold down SELECT and the RED key together for about two seconds, until the red light (LED) on the remote blinks twice...key in the remote code for your model of TV on the remote keypad ( for Goodmans, try 065, or 0335 ) then press SELECT button ( the LED should blink twice to show code accepted ) press SKY button to exit. point remote at TV and test.....Job Done . !
Posted on Dec 14, 2007
epik559
  • 44 Answers
SOURCE: code number for sky remote
Call the manufactor of that remote and ask for Funai remote codes.
Posted on Jan 03, 2008
SOURCE: PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Posted on Sep 29, 2008
  • 393 Answers
SOURCE: hi there i need code for sky remote to pair up to
if you look inside the battery compartment there should be a revision number for the remote.
for a LE40b652 use -
Rev 4 or 6 Remote - 0646 or 0502 or 0615
Rev 8 Remote - 0646 or 0840 or 1340
Posted on Feb 28, 2010
welsh babe
SOURCE: REMOTE CODE FOR SKY REMOTE FOR BUSH A642F LCD
the code is 253
Posted on Apr 17, 2010
What is sky remote code for LG 42LB5500
It depends on the Rev. number of your remote. Older Sky remotes are programmes for different models compare to new ones.
A surerfire way to set this up is to use the Sky "Program my Remote" feature from the Sky box itself (it's in the Help menus), or direct from the Sky web page: http://sky.uebv.com/ Each way will ask you to chec k the revision (rev) number from the sticker inside the battery compartment.
Sky com Find your remote control code
Sep 07, 2014 | LG Televison & Video
Need a code for my philips to reprogramme my sky remote my model is 28pt4458/05
Try these codes.
0081
584 065 040 041 582 221 115 071 351 402 034 219 451 371 035
Philips
14PT3685/05 21GR2550/058 21PT532A-05 21PT161B-05 21PT166A/03 MD12E 29PT828C/05 32PW9615/05 28PW6322/05 32BW6332/25 28WVRN 32PW952505 SL6-1 25ST1761 25PT727B/05 21GR2554/05B 28PW6606 21PT161A105 32PW9566/05R TW6328 28MD12E 28PT/4523/25 32PW9525C 28PT4521 24PW6006/05 32TW6517 32PW8515/05 32PF99445/12 42PF9945/12 21PT5505 23PF99445/12
Philips
20PV164/05 20PV230/07 24PW632405R 25PT4475/05 25PT4523/05 28PW6516/05 28PW5324/05 28PW6315 28PW6515 29PT9113-05 29PT828C/25 32PW6322/25 32PW631S 32PW6517 32VW6005 32PW962B 32PW6006/25 32PW6526/05
Apr 19, 2012 | Philips Televison & Video
Need code for polaroid tv for sky
I've posted a clarification request above. You need both the TV model number and the version number of the Sky remote to find the correct code. I install satellite systems - I have access to the entire code database for all versions of Sky remote.
Oct 19, 2011 | Televison & Video
Sky remote codes for television model 42PF9631D/10
Hi
The correct code (or whether there is a code at all) depends on which version of the Sky remote you are using. The version number of the remote can be found on a sticker inside the battery compartment. If you have "RC1600/00" "Rev 4" or "Rev 6" on the sticker, then it's unlikely that it will work with your TV, but please read on as this isn't always true.
If you have a "Rev 8" remote then it's more likely to work with your TV, however, according to Sky, you will need to buy the new "Rev 9" Sky remote:
http://www.thedigiboxshop.com/sky-hd-remotes-sky-hd-remote.html
If buying one, be sure to check the button for the "Rev 9" version ( £0.85).
The actual code for your TV model is: 0718
I suggest you try the above code regardless of which version of Sky remote you have as Sky's information is not always accurate. You can also try these generic codes for Philips TVs:
0584, 0266, 0065, 0749, 1679, 0199, 0679
Again, try these with whichever version of the Sky remote you are using. There is a good chance that one of them will operate the volume and power functions on your TV. If none of the above codes work, then you will probably need to buy a Rev 9 remote.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
I have a toshiba regza hd ready flat screen tv. Need to program the sky remote for it but do not know the model number. Can't find it on the tv anywhere or find the manual! Any ideas on how I could find...
The model number should be on a white sticker on the back of the TV. If you can find it, please post back and I will obtain the correct code for your Sky remote.
There are some Generic codes for Toshiba TVs which are:
0536 1536 and 1221 for Rev 8 remotes
0063 0536 and 1121 for Rev 6 remotes
0063 0121 and 0536 for Rev 4 remotes
You can find the Rev number of your Sky remote on a sticker inside the battery compartment. If it just says RC1600/00 then you have the original Sky remote, but you can still try the above codes.
If you need instructions on programming the remote, please post back with both your model number and Sky remote Rev number and I will post the codes and instructions.
Regards,
BElectric
Nov 18, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Carnt find code for sky remote to onn tv model
try using the code for thompson as I could not get virgin to work, and it did with the thompson code.
Apr 29, 2010 | Televison & Video
Need the sky remote code for bush s626d lcd tv. cant find it anywhere!!!please help
The Sky engineer told me that there wasn't a code for this model TV but thanks to the guys at:
http://genuinecopies.tv/skyCodes.asp?brand=bush&model=s626d
I was able to find it the code is : 206
This was for a REV Ver 8 Sky remote.
Their code finder should work for other models too.
Feb 28, 2010 | Televison & Video
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
