Question about Epson C11ca45201 Artisan 50 Inkjet Printer, Windows/mac
Unable to use ID card printer application on epson artison 50 with older recommended driver, is there a solution?
Photoshop application says its version is not compatible or the printer is not compatible, which would it be?
3 Suggested Answers
SOURCE: Microsft Vista doesn't support 4990 negaives scanning
I thought I had this problem too...I couldn't select FILM as a document type. I downloaded Epson 3.04A and it still couldn't let me select film. Then I reattached the cord (from the top lid to the main portion) and now it works!
Posted on Dec 06, 2007
Nitrotrike
  • 589 Answers
SOURCE: epson scan application won't open
Do you mean the old powerbook has the same OS as the new one, or the same epson software version?
In any case, this is all I found on it:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58609&prodoid=63060805&infoType=Downloads&platform=Macintosh
Posted on Jan 11, 2008
How do i scan with cx7300
first, you must surely check if the printer/scanner driver and its application is already installed and recognice it.
If not you can download the driver and application here :
http://tech.epson.com.au/downloads/category.asp?sCategory=Multi_Functional&id=styluscx7300&SelOS=Y
Remember to choose driver that support by your operating system.
If all above steps done. use application installed as utility tools to scanning and printing documents.
Sep 27, 2012 | Epson Stylus CX7300 Series
Epson t60 wont print on pvc id card
Change your driver to R290 instead of T60. Select your T60 as printer (with an R290 driver) when printing. That would take the CD margin off the PVC card your printing on.
Aug 17, 2012 | Epson TM-T60 Printer
I can not get the printer to print
I am assuming you are trying to print from a computer, not a photo memory card (SD Card).
Try the following things:
- get the manual and install CD if you have it
- use the manual or the menu on the printer to print a test page (if that works then it is probably not the printer)
- make sure the USB-B cable is connected
- Start the Print Manager software on your computer (install it from the CD if it is not installed already, download the drivers from on-line if you do not have the CD)
- Use the Print Manager to print a test page (If this works, then we know the cable works)
- in Control Panel under Printers select the Epson Stylus as the DEFAULT PRINTER
- from the application (MS Word, Photoshop, etc.) try printing and verify that the Epson is the selected printer
If this does not work please provide further details about what hardware and applications you are using and what you are trying to print.
Good luck. Bry
Jan 01, 2011 | Epson Stylus RX580 InkJet Photo Printer
I HAVE A MAC PRO AND I use photoshop CS3, SINCE I have my new computer and cs3 I'm be unable to print
hello, what is the operating system on your mac, you may need to update the printer driver, go to epson web site and check.
Sep 30, 2010 | Epson Stylus Photo R2400 InkJet Printer
Epson perfection application not working on G5 10.5.8
hi there. you actually downloaded the right driver :
try this Run Photoshop in Rosetta mode; Epson Scan 2.77A only runs in Rosetta mode.
Follow the steps below to run Photoshop in Rosetta mode:
  1. Open the Hard Drive, select Applications > Adobe Photoshop, then select the Adobe Photoshop icon.
  2. Hold down the drv_mac_407_er.gif-I keys to open the Get Info window.
  3. Check the Open Using Rosetta option, then close the window.
  4. Start Photoshop.
Dec 23, 2009 | Epson Perfection 1250 Flatbed Scanner
Wont print out accurate color when printing a Greyscale photo
Hi, I recommend doing a nozzle check first to ensure all the colours are printing fine.
Within the advanced option of the printer driver you have an option to select greyscale, it might be worth enabling this feature.
If you are using glossy media the problem might be down to the ink reaction with the glossy resin as this can cause casting or bronzing. To check this try printing on matt paper.
If you are printing from Photoshop check your colour matching settings, the easiest way to do this without messing to much is try printing from another application, I would recommend Epson's own, Easy Photo Print.
Dec 04, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R340 Faces in photo are printing day-glo green
Possible printhead or driver issue.
Are you using Adobe photoshop? Please try to print also using a different application to isolate the issue.
Make sure that you are using correct epson cartridges.
Please print a nozzle check pattern. If you see gaps, missing colors or missing lines on the pattern, clean the printhead using the driver.
If the nozzle check pattern printed out successfully, please trash and re-install the drivers. The driver is available on epson.com
Apr 29, 2009 | Epson Stylus Photo R340 InkJet Printer
trash and reinstall the epson scan software and download latest driver for your devices use this link support.epson.com and download drivers for win vista.
Apr 01, 2008 | Epson Stylus RX425 Multifunction...
Epson 2400 printer prints dark and with slight colour cast
try these :
1. nozzle check
2. image set to RGB color (Photoshop)
3. check driver settings
4. try another file
5. try another application
6. ¨supported / recommended¨ epson paper & inks
7. another computer (to pin down where issue is happening)
8. all else fails - the printer needs service (better check your warranty status)
Jan 03, 2008 | Epson Stylus Photo R2400 InkJet Printer
Epson C11ca45201 Artisan 50 Inkjet Printer, Windows/mac Logo
16 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
