Question about Mitsubishi VS-55601 55" Rear Projection Television
Mistubishi WS-A55 I own a Mitsubishi rear-projection and had tech come out to replace lamps under warranty. I found out later on whil watching sports that the screen adjustment is off level and "pushed up" (top of the sports ticker is halfway cut off) Anyone know how to adjust the screen?
Did you try changing the format narrow-standard- i like Stretched
( Expand & Zoom Not Good )
i just ran onto this site looking for a problem, probaly Wont be back good luck Larry
Posted on Feb 16, 2009
Bad Lamp for TV
Can't get a reception with my ws-a55 tv
Feb 15, 2014 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-A55 with a 2-3 error code
SD Tech - I have the error code 22 on my WS-A55. Power light comes on and then quickly shuts off. Looked at circuit board - there was greenish "gunk" on two of the electronic parts on the board in the center (behind the speaker grill) in the area labelled R5A62. Would you be so kind as to post repair instructions and the name of parts seller you mentioned above? Thanks!!!
Mar 17, 2013 | Mitsubishi WS-48315 48" Rear Projection...
I have a 65" Mistubishi WD - 65734 and have no
Yes,"LAMP" LED light indication front of tv bazel frame is on or blinking,yes mean tv projection lamp life are over.The whole tv warrenty only for a year,tv projection lamp should last at leat 1 1/2 or 2 years,by tv been on and watches used it like 4 or 5 hours daily?U never done tv replacement parts,any kinds before?Yes,hire a tv Tech. to do it.Shop around for a Tv tech.should replaced the projection lamp for u shoud be around $250 to $300 that including part the projection lamp.
Jan 03, 2011 | Mitsubishi WD-65734 65" HDTV
I have a Mitsubishi WS- 55859 projection screen tv and the screen/lamp flashes on and off a couple of times then lamp go off but you can still hear static.The TV is on but not picture is getting to the...
The WS-55859 does not have a "Lamp" it is a 2001 rear projection set with three picture tubes.
Have (if this is the correct model) you tried the self check this set has?
Also do you have this problem on all inputs--tuner, and various rear inputs?
The more you tell me the better I can help you.
Got a IM?
SD TECH
Feb 23, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Mistubishi vs60603
change the coolant in the tubes also polishing the mirror does wonders for brightness levels. dont use windex, just a damp soft cloth then dry
Mar 26, 2008 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi ws-a55 2003 model
this set has self diagnosis, try this first to get error codes. Look here or ctechnicians.com to get info
Dec 31, 2007 | Mitsubishi WS-48315 48" Rear Projection...
Mistubishi ws-65909 will not come on
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get tech says cant repair it this one does,it helps if u have the warranty or protection agreement
Dec 01, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Red Lamp
How much does the lamp light cost. Where do we purchase this??????
Oct 15, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Televison & Video Logo
186 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
