Verizon DSL spotty service
we have verizon dsl in use at our home here, and when it works, it is really great. unfortunately, it seems that the modem that was provided periodically drops the dsl signal, and whomever is using the internet at the time is kicked back to a 'local' connection on the network, rather than 'local and internet'.
the modem provided by verizon is the westell 6100.
after observing the lights on the modem, i have seen that the 'ethernet' and 'dsl' lights on the modem seem to flash, or turn off around when the network on the computers revert to local only.
i was wondering if anyone else has experienced this problem, and if so, how did they fix it?
one minor side note, i have noticed that the phone line and cat-5 cable connection ports in the back of the modem do not have the 'tabs' that click and hold the cables all the way in to the modem, is this a standard thing for this type of modem? or is it something that may be leading to the problem?
  • tom_swartz07 Jan 19, 2009
    hey thanks!
    ill call them asap and see if they could fix it!
    Genius:
  • 1,605 Answers
To answer your first question, call verizon to fix the line. it is dropping. Second have verizon change a dsl and test it out.
as far as the tab on the CAT-5, the tab is to lock the cable in place, without it, it will work but you have no insurace as to the connection status. (need cable with tab).
Posted on Jan 19, 2009
I have Verizon DSL service on my Westell 327w. It
whenever the connection drops, is the DSL light blinking?
because, it is just normal for the E1 light to blink, but the DSL light should be solid at all times.
It can be a possible issue with the cable or the LAN card, but you still need to have your line checked by Verizon to make sure that it is not a modem or a network issue.
Feb 21, 2010 | Westell Wirespeed VersaLink...
I have verizon yahoo with verizon DSL. The
hi,
theres a possiblity that there is something wrong with you adobe reader of flash utility,try to update it
thanks and God Bless
Feb 01, 2010 | Yahoo Mail
Can't connect work laptop to router (wireless or
Your work laptop probably has proxy settings in the browser. If yes, please remove it adn try. That should help .
Thanks
Ranjit
Jan 05, 2010 | Actiontec Electronics (GT724WGR) Retail...
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Jul 11, 2009 | Westell Wirespeed VersaLink...
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
DSL loses signal during VOIP call.
hi,
i worked for verizon for two years and I encounter this problem many times,to tell you honestly,its not with you internet connection since if you'll notice,while you are connected to the internet and you make a call or call someone,its interrupted... Obviously,its the phone itslelf,the signal comng from the phone is different from the signal of the internet...thats the reason why you need a modem to convert the signal coming from the phone line to make it work for internet,,,what I suggest is you change the DSL plan from the Dry Loop to the regular dsl with the phone...
Mar 20, 2009 | Westell Wirespeed LiteLine 6100...
Trying to hook verizon UM150 card to verizon wireless DSL Gateway
the UM150 wireless card goes into the computer.
however, the DSL need to be wired to your computer for initial configuration.
if you just hook up the DSL as verizon say, then you will have a open wireless network, anybody can get access to your network.
Feb 03, 2009 | Verizon Communications Ethernet/Wireless-G...
Cisco vpn will not work with verizon service now after we got a new modem through verizon
Verizon Home DSL service uses a special filter that prevents ALL incomming connection including web, email and VPN hosting from a home connection. Business internet does not limit this, and I don't believe FIOS blocks it. If you have verizon home, there's nothing you can do. If you're just trying to connect to a home machine, you can try something like gotomypc, or a free alternative like teamviewer.com or logmein.com.
If you don't have verizon home dsl, comment back with what service you do have, and we can try some other things.
Steven
Jul 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can only get dsl if i use landline
Hi, Rob just studied ur problem.Iam a tech which handles this kind of issue. I talk to verizon,at&t,bellsouth,qwest daily for such issues. Well i can suggest u onething u can get the efficient speedstream 4100 series modem which comes with a 1 yr warranty. And also checkout with verizon clearly abt ur distance from the central office.Bcos might be ur dsl circuit may be not technically feasible i:e NTF. For further clarifications plz get back to me.
Jun 07, 2007 | Westell Wirespeed LiteLine 6100...
Computers & Internet Logo
517 people viewed this question
David Payne
David Payne
