Question about Kenmore 24032\24036 Top Load Washer
My kenmore calyspo washing machine flashes code CE
My kenmore calyspo washing machine flashes CE is there any way I can fix it
  • Anonymous Jan 19, 2009
    I have the same problem
    Novelist:
  • 101 Answers
The problem is a communication error between the control panel and the control board and the motor control. You can try unplugging the washer for about 5 minutes to reset it but if that doesn't work you will need to replace one of those parts. Without hooking up a volt meter however to determine which one is causing the problem I couldn't tell you which one. You may need a tech to come out and see what one of those three is the problem. Try unplugging it first though and see how that works. Let me know if you have any other questions and if this was helpful to you. Good luck and I am glad I could help you.
Posted on Jan 22, 2009
My kenmore elite calypso has a code of ce
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
May 09, 2010 | Washing Machines
How do i fix my kemore elite calyspo.with code ca flashing
how are u am scott hope i can help ok i have the same washer this CA code means AVERAGE CURRENT LIMIT, OR INSTANTANEOUS CURRENT LIMIT. if a status comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip, or "CI" for instantaneous current limit trip. AVERAGE CURRENT TRIP occurs if there is a 2-second average of current draw greater than 5.55 amps at the motor windings. INSTANTANEOUS CURRENT TRIP occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. or overloading the unit may cause this problem. press stop/cancel to clear the display good luck
Feb 17, 2010 | Kenmore Washing Machines
The washing machine displays error code CE for communication error
Hi, Well if there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
1.Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
2.Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
3.Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
4· Drive motor thermal protector has opened.
5·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
I hope it helps. Thanks! mannu_rakesh
Sep 02, 2009 | Kenmore Washing Machines
Code ce flashing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 27, 2009 | Kenmore Washing Machines
Error code on kenmore washer
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Top Loader "CE" error code.
CE means communications error
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite calypso 24082 error code CE
On the ccu, the board on the right is usually the culprit, I have recently replaced one with that same error but I would first unplug it and remove and re connect each plug on the board looking for dark connections or dialysis, corrosion. If not fully insert each plug and try again.
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite calyspo washing machine model #110.2206
that washer the noise you are saying i have found maney things the most common one being the break and basket drive
Feb 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
47 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
