Question about Frigidaire Model: PHSC39EHSS
How to fix the evaporator fan on frigidaire refrigerator
2 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
Posted on May 23, 2010
Mine is flashing EFO90 what does this mean it a front load washer by Firgidaire
Frigidaire Refrigerator Error Code = EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Dec 27, 2016 | Frigidaire Washing Machines
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Frigidaire fridge model FGUN2642LF6 fridge is not working. Code displays sy and ef, what is wrong
Your evaporator fan is not spinning.
Check to make sure there isn't any ice build up jamming up the fan. If there isn't then it's either the evaporator fan, or the main board.
Aug 14, 2015 | Frigidaire Refrigerators
How to fix a noisy evaporator fan in a frost free refrigerator
The ice usually makes a fan noisy by filling the cavity it needs to move the blades in. check if this is the case, if there is no obstruction and the fan motor itself is noisy it needs to be replaced or serviced, servicing parts is trickier to find than the little motor it self.
To clear the ice just let the fridge stand for a few hours and to help the process speed up you can spray the evaporator with luke warm water.
Feb 26, 2015 | Frigidaire Refrigerators
How do I access the evaporator fan on side by side model FRS6LR5EW3
Good Morning Friend,
I understand the freezer portion is working on your Frigidaire refrigerator, model# FRS6LR5EW3, but your refrigerator does not seem to be as cool as it should. I also see you want to know how to access the evaporator fan. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to access the evaporator fan with ease. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Refrigerators
What does the error code 5y EF mean on my Frigidaire refrigerator
I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FRS3R5EMB Side by Side...
1st water dispenser not working now EF code
EF code on a Frigidaire refrigerator means Evaporator Fan problem. The motherboard on the FGHC2345LF can be sensing a problem with your evaporator fan. The fan could be failing so I advise that you keep an eye on the evaporator fan. All cooling will stop if this fan fails. I believe you are having two unrelated issues. The=> 241734302 Water Inlet Valve
is possibly becoming defective and not allowing water to dispense.
241509402 Evaporator Fan Motor
I will be here should you have questions, Thanks Sea Breeze
Oct 05, 2012 | Frigidaire FGHC2345LF Gallery 22.6 Cu. Ft....
After power outage the fridge was displaying codes SY and EF I have Frigidaire model number FGHS2365KF1. Any thoughts?????
Hi.
SY: Defective evaporator system. Check evaporator fan, thermostat and heater.
EF: Evaporator Fan defective. Test and eventually replace the evaporator fan.
The problem is likely the evaporator fan. Before replacing the fan test the other parts comprised in the evaporator system.
Here a tip explaining how to test such parts with a similar fridge model: Fridge not cooling. Procedure is more or less the same with your model.
Here parts and diagrams for your model.
Generally you can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Aug 29, 2011 | Frigidaire FRS3R5EMB Side by Side...
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Open Questions:
See all Frigidaire Model: PHSC39EHSS Questions
Frigidaire Model: PHSC39EHSS Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
