Question about Cameras
Take off write protect on camera olympus e-pm2
Need to remove write protect on camera, have checked sd card.
SOURCE: polaroid a300 camera is saying sd protected
Well, make sure you have checked the small gray tab on the left side of the sd card. It needs to be in the unlocked position. Too bad for me, because i have the same problem and my sd card isn't locked...
Posted on Dec 19, 2007
Muzzi_123
  • 749 Answers
SOURCE: Write Protected. What does this mean?
no, there will be a small button on your memory card just 'slide' it the opposite side. its on protect mode.
Regards
Posted on Apr 08, 2009
SOURCE: how to remove write protect
Does the camera support the type and capacity of the card? SD vs. SDHC? if yes Once you confirm this then move the lock switch down all the way and then back up.
Posted on Apr 17, 2009
Steve5
  • 423 Answers
SOURCE: SD card Protected
It sounds like the tiny locking switch on the SD card has accidently been set to "lock". Remove the card from the camera and slide the switch to the opposite position. That should do it.
Posted on May 21, 2009
  • 942 Answers
SOURCE: how do i remove the protected card from my camera
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Posted on Jul 27, 2010
Olympus write protect
What model Olympus camera?
If it uses SD cards, SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 15, 2013 | Cameras
How do you remove write protect from olympus tough tg610
It's not the camera, it's the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2013 | Olympus Software TG-610 3D Digital Camera
I need to remove the write protect sign on my camera
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 02, 2013 | Olympus PEN E-PM2 Digital Camera Body
Write protect sign on olympus e-pm2
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Olympus tg-310 says write protect even though sd card is not on write protect
SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
You may have a software write protection enabled.
Oct 19, 2012 | Olympus TOUGH TG-310 Digital Camera
How do I remove write protect from my olympus fe-340 camera?
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 29, 2012 | Olympus FE-340 Digital Camera
When i switch on my digital camera write protect message is displayed on it , my camera is olympus fe-190
If your camera uses a SD memory card then the write protect switch maybe on.
SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.
May 06, 2012 | Olympus FE-190 Digital Camera
How to fix write protect from my olympus FE 190 model
Good day,
This tip will explain how to remove the write protect from your SD Card.
This is a easy fix and won't take a minute.
First remove your SD Card from your device. You will see on the side of the SD Card that there is a small switch. If your SD Card complains about being write protected simply put the switch in the opposite position. Some of the SD Cards even have the word LOCK on near the switch indicating the direction the switch must be to LOCK the card.
Once the switch is changed you can put the SD Card back into your device and the problem of write protection would be solved.
Please feel free to let me know if this tip was able to help you!
Regards
Apr 05, 2011 | Olympus FE-190 Digital Camera
Every time I turn on my camera a message appears on the screen that says "write protect". What is "write protect" and how do I get rid of the message?
1) It could be your camera has write protect switched on. Go through your camera's menu and look for picture protect and remove it.
2) Your SD card could be write protected. Take out the SD card and check, there's probably a sliding notch on the left hand side, move the to write enable.
Jun 27, 2010 | Olympus FE-190 Digital Camera
MicroSD atchment write protect
The microSD card has no visible write protect tab that you can access: you need to use a Micro-SD to SD/mini-SD adapter that usually comes with your Micro-SD card and use the ON/OFF sliding tab on the adapter to disable or enable the wiite protection on your Micro-SD card: test the access via the adapter card before removing it.
Hope it helps: let me know how you go!
Mar 07, 2010 | Cameras
Cameras Logo
37 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
