Is LG FLATRON E2042 monitor is led or lcd.. - Computers & Internet
Fix-4U
  • 293 Answers
SOURCE: how to disassemble a LG LCD monitor
Hi...there,
There are 2 ways to opened it... 1: from the back, removed 4 screws and get a good grip on both open edges and pulled. Need to give it some force to it. 2: The other, it from the front bezel. First laid it face up and placed a piece of cloth or micro-fiber cloth over the screen to prevent smudges or damaged from the 4 knuckles . Then use both 8 fingers to grasp onto to edges of a bezel and lift it up with some force to it. Do the same on other side Good luck!
Posted on Dec 06, 2008
  • 173 Answers
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Posted on Jun 13, 2009
SOURCE: LG Flatron Monitor-adjust height and color
https://support.dell.com/support/edocs/monitors/1908FP/en/ug/stand.htm#Using%20the%20Tilt,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Posted on Apr 12, 2009
wagyp
  • 86 Answers
SOURCE: lg flatron won't turn on
have u checked the internal fuse take the back off and look for a glass fuse
Posted on Jul 26, 2009
pandeyram1
  • 192 Answers
SOURCE: I need a driver for the LG Flatron L1919S LCD
for what purpose you want the driver for the monitor? generally there are no need to install the monitor driver.
Posted on Apr 01, 2010
I need lg flatron ips234 led datasheet
you can get a manual here
http://www.lg.com/uk/support-product/lg-IPS234V
or here
http://www.manualslib.com/manual/415946/Lg-Ips224v.html?page=12#manual
May 31, 2014 | LG Flatron IPS231B-BN 23 LED LCD Monitor -...
LG Flatron E2042. Brand new. New CPU. Windows 7. I plugged in my new monitor today. Does not turn on automatically. But when I do turn it on I get an error message. D SUB POWER SAVING MODE and tur
Your new moniter may not be compatible with your computer. I have an Emachines that won't take a flat screen. I have to use a big bulky moniter because it says not connected even thought the hookup fits the back of the tower. That might be your problem. Did your old moniter work correctly?
Nov 15, 2012 | Computers & Internet
I need to find the driver for an lg flatron e2041 monitor
You didn't specify which OS you use. So, the following is a link to a compressed package of basic Windows driver files for your monitor directly from LG:http://tinyurl.com/LGFlatron-e2041.
Once you download the "zip" package, navigate to it using Windows Explorer, right-click the package, and "extract all".
Oct 22, 2012 | LG Electronics Flatron E2041T-BN 20" LED...
Lg flatron e2041 driver
http://www.lg.com/lgecs.downloadFile.ldwf?DOC_ID=KRSWD000005447&ORIGINAL_NAME_b1_a1=LG_E2041_Driver.zip&FILE_NAME=KRSWD000005447-b1-a1.zip
Tengo problemas con la resolucion del monitor, me da 640 por 480 y 4 bits de calidad de color sin posibiladades de cambiarla, he formateado desde entonces salio el problema, me falta un driver pero no...
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | LG Flatron 575LM (White) 15.1 in. Flat...
LG Flatron - green power led blinks twice
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | LG Flatron L1750S 17" LCD Monitor
Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
May 18, 2010 | LG Flatron L1919S LCD Monitor
L1750s 17"
This problem is showing when the main PCB of the monitor failed. contact the LG service provider in your area. Here is the link to get the service center info
http://www.lgservice.com/
Dec 31, 2007 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
887 people viewed this question
David Payne
David Payne
