Question about Lowrance GPS
Does thelake insight pro 2012 work in the endura outback gps
I cant get lake contours to come up
3 Suggested Answers
issikiki
  • 563 Answers
SOURCE: My new Endura out&back does
One thing that you need to know that the Fishing Hot Spots cards do not work currently in the Lowrance Endura Out&Back, Safari or Sierra GPS units as these cards are in SD format and the Endura's use microSD format.
A microSD version that will work in the Endura's with full functionality is being worked on.
If your new Endura does not work properly (dept of lake from Navionics...) after being charge (power on and off) you might have gotten a faulty unit. You should exchange it for a new one.
Posted on Sep 02, 2010
SOURCE: why wont my lowrance endura outandback upload the
Two requirements:
1) You must have version 1.4 software on your Endura. Remove the map card, press and hold (10 sec.) the menu key until software information appears to see what you have. Upgrades are available on Lowrance's website.
2) You must have the Endura Compatible LakeMaster map card. These were made available in May 2010. The packages have an "Endura Compatible" sticker on the front.
Call LakeMaster regarding your options if the card is not Endura compatible.
Moccasinboy
Posted on Nov 29, 2010
I need a map chip & onwers manual for a Lowrance HDS 5 like insight. Serial no. 102574610. Where can I get them?
here is the manual
HDS-5, HDS-7, HDS-5m & HDS-7m - Lowrance
https://www.lowrance.com/.../Lowrance.../HDS-5-7-5M-7M_OM_EN_988-10041-00...Sonar references do not apply to the HDS-5m and HDS-7m GPS only units. Manual Conventions. When you are instructed to press a button in this manual, the ..
Software Upgrades here
Lowrance HDS 5 Software Google Search
and finally Mapping
mapping for Lowrance HDS 5 Google Search
and specifically, INSIGHT
Insight Genesis - Download free Lake, River and Coastal Maps
https://gofreemarine.com/insight-genesis/Make your own maps and download free maps from the community. Insight Genesis' cloud-based software does all the work, automatically processing ... with sonar signals from your existing Lowrance, Simrad or B&G transducer. ... The cloud automatically backs up all your data, protecting against lost or damaged SD cards.
Jun 26, 2017 | Lowrance Boating
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
2012 Subaru Outback HD Radio Wiring Harness
What exactly are you needing for your GPS? Are you looking for a power/ground wire to tap into? or are you trying to connect some type of audio? I can probably help, but it would be much easier if I understood more clearly what you need to accomplish.
Jun 02, 2012 | Cars & Trucks
Why cant i get a gps signal
If you are indoors and trying to test it you won't get a signal. If it's the first time using it, or you havn't used it in a long time, it can take 5-10 minutes for the satellites to get your location.
Mar 13, 2011 | Lowrance Endura Out&Back Handheld GPS...
Why wont my lowrance endura outandback upload the 2010 lake master chip put in i updated the firmware and it still wont work
Two requirements:
Moccasinboy
Nov 27, 2010 | Lowrance Endura Out&Back Handheld GPS...
Lowrance Endura Safari screen has gone white.
sorry to say but its broke, same thing happened to me after one day of ownership, lowrance tech support had me return it for a replacement, he called it the white screen of death.
May 31, 2010 | Lowrance Endura Safari Handheld GPS...
How i can reset an a lowrance endura sierra?
Hello there:
here is what you can try to do is first unplug any power going to the unit and remove the battery these units have a internal reset device that will reset it'self after a given amount of time which is about 1 hour.
during this time press in on the power button for 2 minutes and if it has a reset button it press in on this for 2 min leave the battery and the power out of the unit for the rest of the remaining time i had mentioned.
now plug in the power cord back in it and start the unit now if it works ok simply turn off and replace the battery and you are now done ok
Hope this is very helpful for you
Best regards Michael
Dec 22, 2009 | Lowrance Endura Sierra Handheld GPS...
How do you get geocaches on a lowrance endura gps. plez help
Loading Geocaching information on the Endura Safari GPS
You can load individual caches into the Safari as a .loc file or load a pocket query file of up to 500 caches as a .gpx file.
The trick with the Safari is to load these onto the unit using the data cable that comes in the box. Connect the Safari to your computer using the data cable and transfer your .loc or .gpx files into the GPX folder on the device.
These files have to be in this GPX folder to be recognized by the device. It will not work if you load the .loc or .gpx files onto a microSD card and insert it into the bottom of the Safari. I am told that this will be fixed in the 1.2 software update that is supposed to come out at the beginning of December.
Once you have the files loaded, all you have to do is disconnect from the computer and wait for the Endura to restart, go to Main Menu --> Find --> Geocaches and see all of the caches listed. For .loc files, there will be limited information provided from Geocaching.com. For .gpx pocket query files, you will have access to the full description, cache size, terrain difficulty, find log and hints. The great thing about the Endura GPS products is that they have a great filter function for geocaches. I use this with my 7 yr old daughter when I only want to find caches that are easier to find and have full size traditional caches that are more likely to have better "treasure" inside. Hope this helps. Have fun!
Nov 15, 2009 | Lowrance Endura Safari Handheld GPS...
Loading Maps
MapCreate Topo does not have lake maps. There are 'some' maps on Lowrance's web site (Free Enhanced Lake Maps) but you may need to purchase lake maps on SD cards for the area you're interested in.
Jun 02, 2009 | Lowrance iFinder H2O GPS Receiver
Overheated Minn Kota Endura28
This sounds like a fairly big deal. You need to check it water got into the motor. Turn it upside down and see if water comes out of the handle end of the motor. This may be a shop deal.
May 31, 2009 | Minn Kota Endura 30 Freshwater Transom...
GPS Logo
78 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
