Question about Sewing Machines
I need a bobbin cover plate for a kenmore sewing machine, model 385. 1884180. It is about 25 years old.
  • Anonymous Feb 13, 2009
    I also need a bobbin cover. Any idea where to get one?
I too am looking for the Slide Plate for a Kenmore sewing machine Model 3851884180. Did either of you have any luck?
Posted on Oct 24, 2010
Where can I get the cover plate for the bobbin for my old singer sewing machine #AJ952517?
Hi, it's best to try haberdashery shops, also ask people that do sewing where they have their machines serviced, then u can contact same. This has helped me when i needed spares for my sewing machine. All the best. Good luck.
Sep 29, 2014 | Singer Sewing Machines
Bobbin rewinder won't work
it's possible that there is a part inside the machine that could be broken, it would be a good idea to have the machine checked.
Jun 23, 2013 | Kenmore Sewing Machines
I have been told that my Kenmore sewing machine, model number 158.1784080 won't maintain tension because the 1) bobbin case needs to be replace (easy to get, but not from Sears), the zig zag needle...
have you tried any of these sites
sewingpartsonline.com
sewvacdoctor.com
whitesewingcenter.com
sewingpartsdirect.com
sewingwarehouse.com
sewforless.com
Sep 19, 2011 | Kenmore Sewing Machines
On my Kenmore sewing machine Model 1756 when I press the pedal the needle does not move. When I turn the hand wheel the needle does not move. any help out there? or is the machine done for
Disengage the sewing mechanism (like you are winding a bobbin)
If the motor runs fine that way then you have a machine that is frozen.
If that is the case take off the top, bottom, needle plate, needle bar and bobbin cover. Spray all moving parts down with Mean Green and let it sit for about an hour. After that blow it out with canned air.
See if there is any improvement. If so you just need to clean out all the old lubricants. Sometimes I take a hair dryer to loosen the sludge up.
Aug 26, 2010 | Kenmore Sewing Machines
How to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Jul 24, 2010 | Kenmore Sewing Machines
Kenmore Sewing Machine Drop-in Bobbin Tension Adjusting Problems
looped stitches are usually caused by improper tension. when the loop is on the upper side, it may be corrected by loosening the top tension or by tightening the lower tension (turn the tension screws on the bobbin a hair at a time)
since using the machine only a few times it is best to clean the machine from dust (can use a can of air) blow air into the bobbin area and between the tension disks and under the throat plate.
make sure the machine is threaded correctly and bobbin is evenly threaded
Aug 26, 2009 | Kenmore Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Lost the clear cover that snaps over the bobbin
hello it is called the hook cover plate. go to kenmore .com check accessories
Mar 06, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
I took apart my bobbin case, plate andbobbin holder. I can
I had the same problem and can't find my Owner's Manual. I found the answer on-line. Hopefully, you have the same type of bobbin casing. To get the answer, go to www.startsewing.co.uk and choose "How to thread a Sewing Machine". If you have the same type of bobbin casing, you should be able to figure out the proper placement of the parts by looking at the one in the demonstration. I am thrilled (!) and hope this works for you, too.
Jan 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
136 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
