Question about Emerson MS3100 3-Disc CD Changer
How to operate Emerson 3 disc compact disc player
Bought furnished condo.it came with.cannot figure how to operate radio portion of player.can you help ? Thanks
2 Suggested Answers
  • 21 Answers
SOURCE: Emerson 3 Compact Disc Player
Hi
If the machine cant read the table of contents of a disc this would suggest either the lens of the optical pick up is dirty or the optical pick up has failed completely or something directly relating to the optical pick up i.e the spindle or stepper motor, if you can easily acess the optical lens you maybe able to clean it using a cotton bud and re-test, just try this with a dry contton bud to begin with if this gives an improvement you may wish to use a cotton bud with a alchol cleaner like I.P.A,
make light circular movements over the lens. If this makes no difference the machine requires repairing, so consult a local service engineer.
regards
TechSupp12
Posted on Dec 11, 2010
Emerson 3 Compact Disc Player - TOC Read problem - wont play CD
Hi
regards
TechSupp12
Dec 11, 2010 | Emerson MS3100 3-Disc CD Changer
I bought a Radio Shack cd cleaner (cd w/little brush on it) to clean the lens of the cd player however the machine won't recognize the disc when inserted so I cannot figure out how to "play" it. Many of...
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
Jul 16, 2010 | Sony CDP-CE575 5-Disc CD Changer
I want to change the battery
Unless you Have AoolCodes DEALER IS A GOOD IDEA
Disconnecting/Connecting The Battery
Always stop the engine before disconnecting the battery negative lead and make sure the battery positive lead is isolated i.e. wrapped in a suitable cloth.
WARNING: Radio code saving devices must not be used when conducting work on air bag or fuel systems. It must be noted that, when using these devices, the vehicle electrical system is still live albeit with a reduced current flow.
NOTE: Before disconnecting the battery make sure that the radio receiver/cassette player/mini disc player and compact disc player keycodes are known and, that no data is required from the powertrain control module as battery disconnection will erase any fault codes and idle/drive values held in the Keep Alive Memory (KAM). It is not necessary to disconnect or remove electronic control modules.
Always disconnect the battery before commencing repair operations which require:
  • The vehicle to be jacked up
  • Work on the engine
  • Work underneath the vehicle
  • Arc welding
Alternatively a Radio Code Saver may be used. With the battery disconnected, a Radio Code Saver will allow sufficient current to pass to maintain the radio receiver/cassette player/mini disc player and compact disc player memory, operate the clock and supply the door operated interior lights while isolating the battery in the event of a short circuit.
Reconnecting the Battery
WARNING: If the battery has been on bench charge the cells may be giving off explosive hydrogen gas. Avoid creating sparks, and if in doubt cover the vent plugs or covers with a damp cloth.
Always make sure that all electrical systems are switched OFF before reconnecting the battery to avoid causing sparks or damage to sensitive electrical equipment.
Always reconnect the battery positive lead first and the negative last, ensuring that there is a good electrical contact and the battery terminals are secure.
Restart the clock (where fitted) and set it to the correct time.
Re-enter the radio receiver/cassette player/mini disc player and compact disc player keycodes and preset' frequencies, if known.
Following reconnection of the battery, the engine should be allowed to idle until it has reached normal operating temperature as the stored idle and drive values contained within the powertrain control module have been lost. Allow the vehicle to idle for a further three minutes . Drive the vehicle at constant speeds of approximately 48 km/h (30 mph), 64 km/h (40 mph), 80 km/h (50 mph), 96 km/h (60 mph) and 112 km/h (70 mph) for three minutes each. This may cause a driveability concern if the procedure is not carried out. This will allow the powertrain control module to relearn idle values.
Jun 20, 2009 | 2003 Jaguar X-Type
I need a wiring diagram for the stereo and eq of my 93 ford probe
Digital Audio Compact Disc Player
Section 15-01: Radio, Tape Chassis and Digital Audio Compact Disc Player 1996 Probe Workshop Manual
REMOVAL AND INSTALLATION Compact Disc Player, Digital Audio SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Radio Removing Tool T87P-19061-A
Removal
  1. Disconnect the battery ground cable (14301).
  1. Remove the instrument panel finish panel (044D70). Refer to Section 01-12 for the removal procedure.
  1. Insert the Radio Removing Tool T87P-19061-A into the face plate holes until the tension of the tool locking into place can be felt. (There are tension clips that this tool pushes out of the way so the radio can pull out. Maybe you can insert 4 pins that will do the same thing.)
  1. Flex outward on both sides of the radio chassis (18806) simultaneously and pull the radio chassis from the instrument panel (04320) using the tool as handles.
  1. Disconnect the electrical connectors and the radio antenna lead in cable (18812) from the radio chassis.
Mar 17, 2009 | 1993 Ford Probe
CD player of a COMPACT DISC STEREO SYSTEM fails to operate.
There are a couple of questions that need to be answered in order for me to get an idea of the problem and its solution.
1) What is the make and model please?
2) When you load the discs, do you hear them load up one at a time without them actually playing?
3) Is there an indication on the front stating "no disc" or any other message?
Thanks,
Dan
Jan 05, 2009 | Audio Players & Recorders
Volume will not go passed 4
The amp requires a compatible Ai-net Alpine head unit to operate it. I bought one too and didnt know this and im still trying to put all of the peices together to create a working stereo system without buying everything all over again.
Nov 25, 2008 | Alpine MRA-F350 Car Audio Amplifier
Aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Mar 30, 2008 | Aiwa CDC-X304 CD Player
Emerson MS3100 3-Disc CD Changer Logo
32 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
