Question about Samsung UN46ES6100 - 46" Class 45.9" viewable 6 - UN46ES6100FXZA
Samsung LED Tv reset settings
How to reset the initial settings for this TV
4 Suggested Answers
  • 33 Answers
SOURCE: Samsung 40" LED TV Display
Not familiar with this particular model of samsung LED TV, but ghosting and shadowing are usually an accepted manufacturer's defect.
If you're still under warranty or within 30 days of purchase, contact the company that sold you the TV or Samsung warranty department.
If you're out of warranty and you don't wish to deal with this, contact a TV repair shop. They will most likely tell you that it's not worth repairing and recommend you purchase a new TV.
Posted on Mar 11, 2011
headstrong56
  • 493 Answers
SOURCE: HOW TO FIX BLACK SPOT ON SAMSUNG LED TV
return it to the manufacturer
Posted on Jul 17, 2012
Can't get closed caption to not appear Samsung led tv series 56
Closed captioning (CC) usually is enabled/disabled as part of initial set up. It also can be enabled by default when the TV speakers are turned off.
Dec 20, 2016 | Samsung Televison & Video
How can I fix Samsung LED Smart TV UA48J6300AKXXA?
If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure, and memory initialization of many popular brand TVs and other devices are given in detail.
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 23, 2016 | Samsung Televison & Video
I can't turn the closed captions off.
Closed captioning (CC) is an option selected during initial set up. Return to initial set up and disable it.
May 29, 2016 | Samsung UN60D6000 60 Inch 1080p Smart TV...
How to reset samsung led tv to factory settings?
Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu.
Related Reading: How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings.
How to Reset Samsung LED TV to Factory Defaults
Nov 29, 2015 | Samsung Televison & Video
Hello! I have a Sharp Liquid Crystal TV (37" display) and my menu options, specially the picture menu, is fixed. can you help me "unlock" it? Model # LC-37G4U
If the AVC System is switched on but it does not appear to be operating correctly, it may need resetting. In this case, press RESET, shown in the diagram, lightly with the end of a ballpoint pen or other pointed object. This will reset the System as shown below. • AV MODE resets to STANDARD • TV channel returns to initial channel setting (Air:2ch, Cable:1 or 2ch) • Twin picture resets to normal • Audio setting initializes • Dolby virtual resets to Off • Image position initializes
http://electro-medical.blogspot.com/
Nov 07, 2015 | Sharp Televison & Video
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
How do I reset my LG 55"UHD LED LCD 100Hz Model No 55UBB850t TV. When tv was initialy set up we said yes to set top box accidentally but we don't have one. I have TV running through Austar but we ha
http://www.lg.com/us/search/srch_manuals-tab?customerModelCode=55UB8500&mobileFlag=N#
Restoring the Default Settings
mr14_home.png ">w14_settings.png ">General > Reset to Initial Settings
Delete all the TV settings data and reset the TV. All the options in the Settings Menu will be reset to the default settings.
After reset, the TV will automatically turn off and on.
Type the password to Reset to Initial Settings
Do not turn off the power during initialization.
Jan 04, 2015 | LG 55" Black UHD 4K LED 3D Smart HDTV With...
I have a mitsubishi WD 6573TV. Sound Issue. Last night I came home and have picture but no sound. I completely powered it down and let it set overnight. Came in today had sound but could not control
Try a "REBOOT"
Reset, Initialization &
Option Menu
Front Panel Reset & Initialization
Many customer generated symptoms, intermittent symptoms
or symptoms that cannot be duplicated can be resolved
by performing resets or initialization from the front
panel. To avoid making nuisance service calls that may
not be covered under the warranty, ask the customer to
perform the following functions before going to their
home.
The most common are:
• System Reset (Re-boot)
• A/V Reset (Resets Customer Audio/Video
Settings)
• Initialization (Resets all customer options,
settings and menu items)
Use the Front Panel Guide as a reference to quickly
perform the desired function. Note: Button location may
differ by model.
The Reset - Initialization Guide details all resets and initialization
functions.
Front Panel Guide
FRONT PANEL
1) SYSTEM RESET1 - Reboots Set
(Same as Cycling AC Power)
Power LED will flash for about
1 minute.
2) A/V RESET2 <FORMAT+GUIDE>
Resets all Customer Audio/Video Settings
FORMAT GUIDE INPUT
ENTER CANCEL
SYSTEM
RESET
MENU
VOLUME
ADJUST
CH
ADJUST
3) INITIAL2 <FORMAT+INPUT>
Resets all Customer Menu and
A/V Settings
LED DIAGNOSTICS3 <INPUT+MENU>
In case of failure, a 2 digit error code will
be indicated by the POWER/TIMER LED.
1 Perform while the set is either On or Off. (See section on LED Diagnostics)
2 Perform while the set is On.
3 Perform while the set is Off.
Apr 21, 2014 | Mitsubishi WD-65731 65" HDTV
I need to change the language from Zulu to English on my smart Tv
You may have to return to the initial set up procedure to select English.
Apr 11, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
How do you do a hard reset on a proscan tv
Just unplug the TV from AC mains wall socket, and re-plug it back after overnight. This must make it a hard reset.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
Samsung UN46ES6100 - 46" Class  45.9" viewable  6 - UN46ES6100FXZA Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
