Question about GPS
Magellan FX324 Map color gps need 7 pin din connector wiring diagram to power supply
Need a power cable from gps to power supply 10-40vdc.the connector to the gps unit is 7 pin din,the other end is red=12vdc, blk=ground.thanks for the help
ctf1800
  • 4402 Answers
SOURCE: Wiring diagram for Magell RM 3000T GPS universal part 980864
http://www.magellangps.com/support/product.asp
Posted on Dec 03, 2007
SOURCE: Kenwood CD changer wiring diagram
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Posted on Jan 18, 2008
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
SOURCE: Magellan FX324 Map GPS
You can get one at:
http://www.magellangps.com/assets/manuals/fx324_en.pdf
Posted on Jan 27, 2009
  • 4 Answers
SOURCE: magellan sportrak color map problem
DOWNLOAD A FREE USER MANUAL AT
http://www.magellangps.com/assets/manuals/SporTrak_series_en.pdf
.....COINWAGON
Posted on Mar 31, 2009
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Need a power supply cable
Order the cable directly from Magellan.
Oct 29, 2014 | Magellan FX324 MAP GPS Receiver
Magellan FX324 Power Adapter.
Hello i donthave a power conection, i fro Lithuania, tell me please where to 7 pin plus and minus (0) then i startmy magelan pleaseeeeeee
Feb 01, 2012 | Magellan FX324 Color GPS Receiver
I have a Magellan fx324 that freezes every time a i use the plot button. The screen displays "loading..." and then nothing happens and it freezes. Every thing else on it works.
I had the same problem when travelling.
It was a loose fuse carrier.
I stuffed siver paper in the carrier and tighten it up.
Never frozen up again
Oct 08, 2009 | Magellan FX324 Color GPS Receiver
I need a fx 324 user manual.
Enjoy...
http://safemanuals.com/user-guide-instructions-owner-manual/MAGELLAN/FX324-_E
If you need anything else related to Magellan products, then the following is the support page...
Please Rate if you found the above info useful. And please comment if you got what you wanted.
Aug 26, 2009 | Magellan FX324 Color GPS Receiver
I need a power data cable for a magellan fx324. The part number is MGFXP12USB
You can call this number
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971
They can tell you where to buy the specific part.
Nov 15, 2008 | GPS
From pc to Fx324
I want to go to I 95 from home which is easy but then I wans to add on to this same route
Jun 09, 2007 | Magellan FX324 MAP GPS Receiver
MY FX324 COLOR WILL NOT TURN ON
Switch off then push together - MarkMOB + Goto + Power
May 29, 2007 | Magellan FX324 Color GPS Receiver
GPS Logo
197 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
