Question about Dometic RM2652 Refrigerator
Dometic rm2652 does not work on gas or 120 volt the front lights do not work nore does the inside light work
    Top Expert:
  • Dometic Master
  • 8,488 Answers
Check power to back outlet and check for fuses on back board if power bad board
Posted on May 30, 2016
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
  • 51 Answers
SOURCE: Dometic Model # RM2652
Check with a DC meter on fuses to verify voltage is passing then check at the input on back side of the fridge to verify voltage is there. If yes to both it can be the eye brow or the lower control board hard to tell without further testing.
Posted on Sep 07, 2008
  • 51 Answers
SOURCE: FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
SOURCE: Dometic RM2652 or RM2852 not working.
There is a factory recall on these refrigerators. Call Dometic 1800-544-4881 and give them your serial number and model number. Going through the same thing right now. On my Fleetwood Gearbox. Hope that helps. Robert
Posted on Sep 30, 2008
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
Why does dometic RM2652 rv fridge run on electric and gas at same time
12 volt runs board 120 volt runs heater element some have 12 volt heater element and LP
Jul 20, 2014 | Dometic RM2652 Refrigerator
Does not cool on gas or 110 volt
Do you have any lights working on the front panel? If not most lower circuit boards have a small fuse on the circuit board. shut down ALL power before checking for the fuse.The lower board has both 115 volts as well as 12 volts. If the lights are working on the front panel then most likely the lower circuit board is faulty and will need to be replaced.
Mar 08, 2014 | Dometic RM2652 Refrigerator
My rm2552 fridge wont run off of 120 volt power but runs fine on propane any ideas?
I have a dometic rv refrigerator its gas/electric it worked 6 months ago. But can't get it to work now.
Sep 02, 2009 | Dometic RM2652 Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Sep 08, 2008 | Dometic RM2652 Refrigerator
Aug 11, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
118 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
