Question about Whirlpool Cabrio Washing Machines
Machine stops working and wash lite remains on. doesn't spin to get excess water out
SOURCE: Whirlpool washing machine not draining.
Hi thanks for te question. the lid switch is more likely to have failed ,because no drain or spin. check that.
Posted on Oct 07, 2008
SOURCE: excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Posted on Nov 05, 2008
SOURCE: washer filled with water to began wash; once
That sounds like a faulty door switch. This can be tested by a technician bridging the door switch contacts. Check also that the door lock is not stuck inside using a pencil or a small screwdriver, be careful not to damage door lock.
If the door lock was not the problem, then check the water level floater , and also ensure that hot water is filling properly, otherwise the thermostat wont detect right temperature and cycle will stop.
More likely you have a problem with the door lock switch.
Posted on Apr 10, 2009
SOURCE: whirlpool super capacity washer spin cycle stop working
Sounds like you need a new lid switch. Click HERE for prices.
Posted on Apr 19, 2009
SOURCE: Whirlpool 6th sense washing machine doesn't go into high spin
sounds like you have a blocked hose/pump vent hole.......if its holding water in the bottom of the tub it wont spin it will try but the pcb wont let it do the spin .due to pressure switch telling its got water left... pull pipe off pressure switch check holes not blocked check all hoses......
Posted on Dec 30, 2009
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Dec 10, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
Dec 25, 2017 | Frigidaire Washing Machines
Aug 01, 2012 | Washing Machines
Jul 03, 2012 | Fisher and Paykel GWL11 Top Load Washer
Jul 03, 2012 | Kenmore Elite 45986 Front Load Washer
Jun 19, 2012 | Washing Machines
May 16, 2012 | Miele Washing Machines
Oct 27, 2011 | Washing Machines
May 15, 2011 | Washing Machines
Apr 26, 2018 | Whirlpool Washing Machines
Apr 20, 2018 | Whirlpool Washing Machines
197 people viewed this question
