Question about Dryers
May tag dryer problem
It is taking us about 4-5 hours to dry a load
  • armandolrome Jan 20, 2009
    thank Mobilian! lint ball in filter housing.
  • Dryers Master
  • 8,220 Answers
Bad blower wheel.
Posted on Jan 19, 2009
Only gets warm and takes hours to dry
Could be a defective heating element.
Mar 02, 2015 | Dryers
Tip
How to receive the best dryer repair help on FixYa
There are a couple of things that you should include in your dryer repair question so you receive the quickest and most accurate answers.
1. Model Number
The model number can be located on the model/serial number tag that is located on the dryer.
Make sure you get the full model number from this tag and not the model number from the owners manual.
The model number from the owners manual only includes the first few digits of the full model number because they include that owners manual with many similar models of dryers.
With the full model number I'm able to look up factory service manuals, tech sheets, wiring diagrams, factory service pointers and so much more.
2. Detailed description of the problem
At the very least give a brief description of the problem you are having with your dryer.
Descriptions like 'My dryer don't work' is not very helpful.
Describe what is not working. For example is the not heating? Maybe the dryer is heating, but takes a long time to dry?
The more details you can give the better. Instead of saying 'The dryer is heating, but takes a long time to dry' you could go into more detail and say something like...
"I put a load of cloths in my dryer and set it on the auto dry cycle. When I went to take them out two hours later the dryer was still running. The cloths were still a bit damp too. Most of the time I can dry a load of cloths this size in one hour. Why is my dryer taking so long to dry?"
Following these couple tips can help you get a faster and more accurate reply to your dryer repair question.
on Aug 03, 2011 | Dryers
It takes my dryer an average of 4-6 hours to dry a load of towels. A regular load of clothes is about 2-3 hours. What can I do?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 19, 2010 | Fisher and Paykel DGGX1 Electric Dryer
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
The dryer takes about 3 hours to dry whereas it
make sure the vent hose and outside door flapper is clear. Try drying one load with the hose off to see if its better.
Sep 08, 2009 | Dryers
Taking to long to dry a load of clothes
Hi, there are a couple possibitlies. Is the 4" vent that goes outside clean or free of a kink in the vent? This unit has a double element, one side of the element might be broke. Check you vent (even the vent flap outside) and let me know please.
Thanks
Vic
May 15, 2009 | General Electric DCVH680EJWW Dryer
Dryer takes hours to dry one load of clothes
I WOULD SAY YOUR DRYER NEEDS CLEANING OUT OR YOUR WALL VENT IS CLOGGED AND NEEDS CLEANING OUT-MIKE
Mar 04, 2009 | GE Dryers
Not drying properly
The heater coils or going bad. It has two wire rings that heat up. One has bunt out.
Jan 16, 2009 | GE DBSR453EBWW Electric Dryer
Takes almost 4 hours/timed cycles to dry 1 load of bedding/sheets
most of the time your complaint is the home owners house venting.run a load with the venting detached[it wont hurt a thing] if ok then must clean venting till dried as well as with out venting.if still long dry times first must make sure air ways in dryer are clean[should have good air flow at back if hand held there] and may need to remove front to clean lint filter area.and inspect blower ,making sure mounted to shaft and not worn in the center[blower key way, inside the hole where motor shaft goes thru blower]you dryer only has one element so if you have heat its heating.if you did all above and have problem still can be electronic[thermostats,timers etc........but i have fixed 1000s of dryers and their having problems are rarer.i hope that helps God bless ,tom
Jan 08, 2009 | Maytag Dryers
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
