Question about Singer Sewing Machines
Singer fashion mate 5500 bobbin thread keeps breaking
Brand new machine and the bobbin thread keeps breaking
  • 7 Answers
SOURCE: was given an old model Singer 237 Fashion Mate
If the bobbin is in the casing correctly then follow these steps...spin your wheel toward you until the threaded needle drops a thread around the bobbin casing it will slide down around the casing from center to the right and down. one the thread is just over half way around gentle pull the tail of your thread from the needle. It should move up and to the left collecting the thread from the bobbin casing. and a loop will arise below your presser foot (which should be up).pull that loop up until the tail of the bobbin is visable. Now you are ready to sew.
Posted on Aug 16, 2009
  • 3741 Answers
SOURCE: Singer Fashion Mate digital error E4.
E4 error.its the bobbin shaft error.first try to clean the bobbin case then turn the machine on for some minutes then turn on and check out.if still the same error then
Check the bobbin winder shaft. If it is pushed over when you try to run the machine you may get the error.adjust it properly.and check out.
if still the same problem the bobbin shaft needs to be replaced.as its slipping out.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Oct 20, 2009
SOURCE: top thread gets tangled in bobbin and won't pull up like
I'm new to sewing, and I had a similar problem where the top thread went all the way around the bobbin thingy and got stuck every time--solution: the bobbin case wasn't all the way in.  The arm had to go in a slot at the top and it sort of snapped in, then it worked fine.  Maybe it will help you!
Posted on Nov 06, 2009
SOURCE: Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Posted on Dec 29, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
Will the bobbins for my old singer fashion mate work in my new singer one machine?
Most likely, not. However, you can try it and see. Or check what bobbin each machine uses. If they use the same class bobbin, then they are interchangeable.
Search for:
Make Model bobbin
Aug 30, 2017 | Singer Sewing Machines
When threading machine, thread won't stay in place at step 4, so when I move thread to step 5, thread comes away. Only bought mchine in March.
When threading the upper thread, be sure to always raise the presser foot. This releases the tension disk and allows the thread to seat properly.
Here's a video that may be helpful:
Singer Fashion Maker 1409
May 15, 2016 | Singer 1409 Promise Sewing Machine
I have a Quantum CXL Singer sewing machine and the thread keeps breaking. It will make about 3 stitches and breaks. It is breaking in the same place.
Make sure the thread coming off the spool is not wrapping around the spool spindle. Install a brand new needle. Remove ALL the thread from the machine. Clean bobbin area of any dust, lint, threads. Set upper tension to the midpoint. RAISE the presser foot and then totally re-thread the machine from beginning to end verifying the sequence is correct. Test.
Why Does My Sewing Machine Top Thread Keep Breaking Howcast
Oct 06, 2015 | Singer Sewing Machines
How to fix E2 code on Singer Fashion Mate 5500 sewing machien?
I would take it back right now. Don't wait for another E2 error. I would take it back and get a different brand of machine.
Sorry... but Singer doesn't have the quality it once had.
Aug 08, 2012 | Singer Sewing Machines
My singer model 237 makes a stitch that doesn't look right. The bottom thread is just goes through the top thread loops under the material
Hi, if stitches are off, there is a problem with balance between the upper and lower stitch adjustments. You have to tweak these. Also, make sure there is no lint in the bobbin case area or under the feeddogs. Here is an excellent blog for 237 Fashion Mate owners. You are lucky to have one of these from the 1960's. http://blog.sew-classic.com/2010/02/02/singer-237-fashion-mate-sewing-machine-reveiw.aspx
Happy Sewing!
Jul 17, 2011 | Singer Sewing Machines
Was given an old model Singer 237 Fashion Mate with no manual. cannot get the bobbin to thread properly.
We'll here is a picture of what I need help on I need to know how to put the needle back along with the needle clamp screw
Jul 09, 2009 | Singer Sewing Machines
Sewing Machines Logo
52 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
