Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Broken "ready tools dial"
The "Ready Tools Dial" that you switch from "floor cleaning" to "Tools for Pretreat" does not appear to be working. The switch feels loose and the machine is no longer sucking the dirty water back up. How do I fix this? I cannot seem to get to the inside of this dial - no readily visible entrance to that compartment.
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: floor cleaning / tools or pretreat lever appears to be broken
That grey lever needs to be closed while floor cleaning. You only open it when you use the hose.
Posted on Mar 27, 2008
  • 37 Answers
SOURCE: Cannot switch it back and forth from floor to hose
yes it is sold separate. its called the divertor and can be purchased from bissell or one of there dealers. hope this helps. if you need assistance with the installation i would love to help after purchasing the part.
Posted on Sep 26, 2008
  • 3 Answers
SOURCE: I am not getting any water to come out of the floor part or tools
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on Dec 01, 2008
SOURCE: HOOVER SPINSCRUB WONT SUCK UP WATER...BLOWING AIR OUT
ITS THE DUCT PIECE ON THE FRONT OF THE DIRTY WATER TANK (DWT). ITS NOT LINED UP.
1. TAKE LID OFF OF DWT
2. SLIDE THE LITTLE SQUARE PIECE (5'X5'X1) (THE DUCT) ON THE FRONT OF THE DWT AS FAR UP AS POSSIBLE AND IF IT BENDS FORWARD FROM THE TOP, DO THAT TOO (SOME MODELS OPEN LIKE A DOOR TOP DOWN, OTHERS JUST SLIDE UP AND OUT COMPLETELY)
3. SLIDE THAT DUCT BACK DOWN AS FAR DOWN AND BACK AS IT WILL GO.
4. PUT THE LID BACK ON BY HINGING THE FRONT LATCHES ON AND THEN SNAPPING THE BACK SIDE DOWN.
5. CHECK TO SEE IF THAT DUCT PIECE ON THE FRONT IS LOOSE BY PUSHING ON IT AND SEEING IF IT MOVES UP AND DOWN.
IF IT IS, THE LID ISNT COMPLETELY ON, GO BACK TO STEP 4.
IF THE DUCT IS SNUG, CONGRATS YOU SHOULD HAVE JUST MADE YOUR STEAM VAC **** UP THE WATER AGAIN
Posted on Dec 03, 2009
Tool attachment won't **** up solution
Check to make sure the Floor/Tools dial is set to tools. The dial should be on the side of the unit or on top of the dirty water tank depending on your model.
Aug 05, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
How do you work it?
below is a website to retreive a free manual for yours. have the model number ready so you can find it much easier....
bye.
http://homeappliance.manualsonline.com/manuals/mfg/bissell/bissell_vacuum_cleaner_product_list.html
Feb 07, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Doesnt pick up water
Possible Causes Remedies
ReadyTools Dial may be at the wrong setting for the cleaning job <> Set ReadyTools <> Dial to either Tools / PreTreat or Floor Cleaning.
Nozzle Window may not be properly attached. <> Press down firmly on the black oval gasket at the top
Window to make sure the two tabs on the back of the Nozzle Window are snapped into the mating slots in the main housing.
Tank-in-Tank lid is not installed <> Re-install lid;
Tank lint filter is blocked <> remove all lint and debris from Tank lint screen.
Tank-in-Tank is not properly seated. <> Tank-In-Tank must be firmly seated to function; remove
and reseat Tank-in-Tank.
Poor tool position (Hand held attachments only). <> Adjust angle; apply more downward pressure.
Tank-in-Tank has picked up maximum dirty water <> Empty Tank-in-Tank
Front Clear Floor Nozzle Window ids blocked <> Remove window and clean all fibres and debris then replace.
Insufficient suction <> Clean Pre and Post Motor Filters.
Sep 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Hi There!
Nov 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Sep 19, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell ready tool dial broken
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sghs
Aug 30, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 9400 ProHeat Upright Upholstery Hose
Set Ready Tools Dial to the Hose
Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean
, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
May 26, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Floor cleaning / tools or pretreat lever appears to be broken
Mar 26, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
324 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
