Canon MP630 Error code C0003. What is this error and how can one fix it? Thanks
komguy
  • 2306 Answers
SOURCE: Hi there , my canon MP630 has all of a sudden 6c10 error ?
That error says that either something is jammed in the purge assembly, the unit on the right that cleans the printhead, or the purge assembly is stuck or broken. If you unplug the printer with the carriage in the center you can use a flashlight to inspect the area on the far right where the printhead parks.
Posted on Nov 05, 2009
cene765
  • 787 Answers
SOURCE: canon mp630, error 5050....what this mean?
It's mean carriage lift mechanism error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Posted on Nov 10, 2009
  • 421 Answers
SOURCE: My Canon MP630 has a 6C10 error
You have a "Valve Cam sensor error". Usually caused by paper debris inside the printer, probably near the purge unit.
Have a ggod look inside and see if you can see any bits of paper.
Posted on Jan 08, 2010
SOURCE: What does error 6000 mean on Canon MP630? It
Error 6000; Fehler 6000.
"Error 6000 is a mechanical problem of paper-input." (Hotline)
Remove paper-tray and check the rail inside as deep as you can see. (look for stuff!) Then try again. All other atempts are hopeless and send it to service.
Ich habe die abstrusesten Antworten im Net gelesen:
z.B. "Fehler 6000 bedeutet, dass die maximale Anzahl der Drucke erreicht ist und das Gerät wegzuschmeißen ist!"
Ich habe beim Service angerufen. Die meinten, es liegt ein mechanischer Fehler im internen Papiereinzug vor.
Das Gerät muss eingeschickt werden. Reparatur von eigener Hand aus nicht möglich.
Papiereinzug? Ich habe dann die Schublade einmal ganz rausgezogen und nach Störteilen auf der Schubladenbahn gesucht.(und gefunden!) Tatsächlich ging die Schublade danach sehr leicht wieder rein und der Drucker lief wieder. Alle anderen Recherchen sind m.E. vertane Zeitverschwendung!
Posted on Mar 25, 2010
  • 1218 Answers
SOURCE: 6c10 error on my canon mp630. There does not appea...
It's probably a waste absorber issue.
A fix from FixYa Support:
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
3. While holding the Power button, release the Resume Button.
4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
http://www.fixya.com/support/t5998845-error_code_6c10_mean
Hope this helps.
Posted on Sep 27, 2010
I have a canon mp630
It has been reported that some manufacturers have issued an update which can cause the printer not to run generic cartridges, could also be a faulty cartridge, change this first.
Jun 01, 2014 | Canon Refillable Cartridges For Pixma...
Canon pixma mp630 error u052
FYI, Canon inkjet printer class action suit
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
Mar 29, 2012 | Canon PIXMA Office Equipment & Supplies
I've lost my user manual for my cannon MP630 and haven't printed photos before so how do I print photos on a canon MP630 Problem
Paste the following link in your browser & download the onscreen manual for MP630.
http://support-in.canon-asia.com/contents/IN/EN/0300129901.html
sonsunny
Jul 09, 2011 | Office Equipment & Supplies
My Canon MP630 has been showing error code C000 for months now. I tried turning it on and off, exchanged all the catridges, looked for jammed paper, removed the print head. Any solutions or should I just...
Hello there,
The C000 error is cause by the ink cartridge not being seated properly. Here are some instructions from Canon on how to resolve it. If this doesnt work, try to replace your ink cartridge. If still you are having issues, it might be that the ink cartridge cradle in the printer is faulty. I hope this helps! Thumbs up are much appreciated.
http://canoncanada.custhelp.com/app/answers/detail/a_id/11015/~/lcd-error%3A-error-c000
May 07, 2011 | Computers & Internet
6c10 error on my canon mp630. There does not appear to be any paper debris and I have been turning the rotten thing off and on for weeks now to get it to work
Hope this helps.
May 19, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Jan 08, 2010 | Canon Office Equipment & Supplies
Nov 05, 2009 | Canon PIXMA MP540 All-In-One InkJet...
My pixma mp630 had a paper jam which I fixed. Now
The error is the APP position error. Uusually caused by foreign object in feed system or Auto sheet feeder. Check for bits of paper in the feed system.
Oct 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon MP630 error code 6502
Error 6502 is the ink tank position sensor error. Basically means the printer can't see the inks. Try reseating them. If this fails you need to send it back.
Jun 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
k24674
jasbo
jasbo
