Question about KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range
Kitchen aid gas range knob doesn't turn
One of the knobs won't turn. Seems locked. Others work fine.
3 Suggested Answers
  • 91 Answers
SOURCE: kitchen aid gas range igniters won't stop
Jammed and broken ignight switch or the spark generator transformer has a short circuit
Posted on Jul 14, 2011
Electric stove top. Only the warmer drawer knob works. Why don't the others?
THE HEATING ELEMENTS COULD NOT BE MAKING A GOOD CONNECTION,TRY PUSHING THEM IN.
Jul 05, 2015 | Kenmore Kitchen Ranges
How do I turn on the Self cleaning process?
Shut the door on the oven and turn the "Delay Start Time" knob to the current time. Turn the "Stop Time" knob to 3 hours away from the present time. Turn the "Oven Set" knob to "Clean" and slide the oven door's lock into the locked position. I hope this helps.
Dec 26, 2011 | Kenmore 78732 / 78734 / 78739 Gas Kitchen...
GAS OVEN KNOB STUCK
The valve is 'seized'. Grease gets into them and over time turns acidic corroding the valve from the inside out. Replace the valve. Any appliance parts seller can get it for you. Turn off the gas before starting repairs!
Apr 30, 2017 | Whirlpool SF325 Gas Kitchen Range
We have an old O'Keefe and Merritt stove in a
on most stoves where gas line connects around back should be a gas shut off valve if none put one on
Jun 06, 2017 | Kitchen Ranges
Old (30 yrs?) tappan gas range.loose oven knob
remove top of range, locate shaft from knob that is loose, there should be a nut where shaft goes into valve, tighten nut in small steps
Sep 17, 2009 | Tappan TGF320 Gas Kitchen Range
Oven wont come obut igniter works
Yes, it could be the knob or the oven control.
If the knob fits tightly to the control, and turns the stem of the control, then I would be suspect of the control. But if the knob fits loosely, I would be suspect of the knob.
Jan 29, 2009 | Frigidaire FGF316 Gas Kitchen Range
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Oven
Hey ascollins217
This is normal with a gas range. The oven is lit with an ignitor (the glowing that is seen) - it glows first then the gas comes on and lights up shortly afterwards. There is no clicking sound for the oven (at least not for the model you have)
Regards
Sep 06, 2008 | Frigidaire FGF316 Gas Kitchen Range
Hotpoint Gas Range (model: RGB524PN1AD)
pull the knob off note the position of the brass gas valve turn the knob 90 degrees see if the position of the brass piece changed the same as knob if not inspect the knob see if its cracked also look on the shaft see if there is a small d shaped metal piece on it if there is it goes up inside the knob let me know what you find will advise from there
Jan 21, 2008 | Hotpoint RGB524 Gas Kitchen Range
KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range Logo
111 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
