Question about Hoover Washing Machines
How do i manually drain my Hoover automatic washer 1000 aristocrat?
2 Suggested Answers
  • 6277 Answers
SOURCE: i just need to know
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jun 14, 2011
Why my hoover is not drying very well its an automatic machine
Make sure the drain line isn't clogged with a sock or something small. Some models have a lint trap, usually at the front, that requires periodic cleaning. If the trap or drain line is partially obstructed, a first load's rinse water won't drain completely in the lowest part of the vertical drum you can't see. If this doesn't solve your issue, there is a pump problem.
Apr 09, 2015 | Hoover AAA160 Front Load Washer
The functions has stoped but the door is not getting open.the model is hoover nextra.what i should do to get the door open?
switch off at the wall then manually drain the water using the (emergency drain outlet near bottom) if your model does not have one of these turn on and off at wall then set the wash programme to drain only this will be indicated in the manual of on the programme guide on the front panel.
Now your door should unlock once the water is drained.
Feb 28, 2011 | Hoover AL120 Front Load Washer
Will wash but won't spin unless water syphoned off by draining through pipe into low bucket. So, the spin motor is ok, the pipe is not blocked... but the pump..... how can I get to clear out the pump?.......
Check to see if there is a filter located at the bottom front of washer behind plastic trim, if no filter, then remove rear panel of washer, and remove and check pump for blockage or malfunction.
Please rate my so9lution.
Thanks
Nov 01, 2009 | Washing Machines
Hoover VisionHD won't drain
This is joyce
I think you better check to see first of all if it is your pump,, that is the first thing to go.
thanks
joyce
Feb 03, 2009 | Hoover AAA140 Front Load Washer
HOOVER 500M0AUS WASHING MACHINE
I have a Second Hoover HTC243 , I don't have the user manual . I don't know how to use it , can u tell me how to use it
Aug 15, 2008 | Hoover HTC243 Top Load Washer
Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Aug 19, 2007 | Equator EZ 3600 CEE Front Load Washer /...
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
