Question about RIM BlackBerry 8800
Blackberry 8800 Kills Battery within 12 hrs. Replaced 2 batts.
I am trying to figure out why my 8800 is eating battery charge. I thought it may be a weak battery, so I purchased one, same thing again, thought maybe a bad battery, so i purchased another one.. still same problem.. Any help would be great.
    Problem Solver:
  • 14 Answers
There are a lot of little things that drain the battery. i have made adjustments to my phone and the battery lasts me 3-5 days depending on its usage.
1. turn off the LED coverage indicator(usually blinks green when u have signal, red when u dont)
2. change your back light timer to 10, 20, or 30 seconds.
3. do not overcharge the phone, it will lower the capacity level of the battery. only charge it when its low and take it off when its full.
4. check the reminder notifications from messages/voicemail/txt,etc. set it to one or two.
5. check to see if you are roaming or searching for service. the constant searching drains the battery.
6. check to see that u have exited the programs u were using. if u have installed maps,navigation, etc and just back out of the program without exiting the GPS is constantly updating your position.
Hope this helps.
Posted on Feb 23, 2009
    President:
  • 625 Answers
Are you having issues at all with the trackball? I had an issue where mine wouldn't click and phone was eating through batteries. Turns out the keyboard was the problem
Posted on Aug 03, 2009
98 Jimmy has a power draw it kills the battery within 12 hrs if you pull the 50 amp fuse for the int batt draw goes away any ideas
Yes Steve I do , that fuse supply's power to the I/P fuse block inside the vehicle . It powers AUX/PWR fuse #13 -20amp , RDO/BATT fuse #19 - 15amp ,MIR/LKS fuse #7 - 5amp , CTSY/LP fuse #8 - 15 amp , CIGAR/LTR fuse #2 15 amp , PWR/LKS fuse #14 15 amp , HDLP/SW fuse #1 - 10amp .Do you know where the I/P fuse block is ? You would need to do a parasitic draw test ! This involves hooking up a amp meter in series with the negative battery post an negative battery cable . Pulling each one of these fuses till the battery draw stops ! How To Perform Parasitic Draw Test EricTheCarGuy check out Eric the car guy's video on the subject !
Sep 14, 2015 | Cars & Trucks
Earlier this year, I purchased a new Ryobi P103 LI-ION 18 V/24 Wh battery powered blower. In the past week, the battery isn't holding a charge for more than 5 or so minutes. Any suggestions?
Try to discharge the batts to the full end.Then try charge them agian for at least 12 hrs.
Or contact them at https://register.ryobitools.com/contact_us/new
Nov 03, 2010 | Ryobi Multi-Volt Battery Charger
Good day all, my blackberry bold 9000 battery drains within 4 hrs after full charging. I have done the following to stop it to no avail: 1. GPS - off 2. Wifi - off 3. Data service - off 4. Memory...
Try this test: remove the battery and place it on a flat surface. Try to spin in. If it spins like a top, the cells are bloated and it needs replaced. Whether it spins freely or not, cell phone batteries significantly decline after 12 months of use.
Sep 10, 2017 | Cell Phones
My blackberry wont turn on
try a new battery? maybe your battery is dead maybe the phone wont charge your old battery do some elimination to figure out the problem
Feb 16, 2010 | RIM BlackBerry 8800
How long to charge battery?
bateries have their own specifications.You can read it on the label.But,most of all it must be charge from 12-15 hrs. on its very first charging ( for a new battery) and later on or for the second time and so on, you may charge it 2 to 4 hrs.,sometimes 8 hrs..Leting you know,a battery can be charge even a short span of time,for example is 30 minutes only.In that 30 minutes try to measure its stored volt using a volt meter or a multi-tester,and the result is laready 12 volts (if your batery is 12 volts.)do you believe that? YES.! because a battery is so easy to store power.But,the problem is that its so easy to drain its stored power.You know why?because the current or amper of the baterry is still weak that the given specification.,.So,for short explanation,the longer time you charge your batery equals the longer time to drain the power.For example: when you charge the batery within 4 hours,thus the batery will be drained after 4 hours.
Oct 31, 2009 | Black & Decker 8 Inch 12 Volt Cordless...
My battery charge does not last more than a couple of days
Friend the battery is drain. You need to empty the batt then cover it with a paper put tape to avoid getting wet then put it in the freezer and after 12 hrs.remove it and let it dry totaly.then after drying charge the batt 4-6 hrs. and it will be back to normal.as new
Jul 10, 2009 | LG KU990 Viewty
Blackberry 8800 will not charge on wall charger
You need to find out if the problem is with your current AV charger - the battery or the phone.
Clean the battery and the metal connection with a dry cloth, and try to charge using a USB charger.
May 21, 2009 | RIM BlackBerry 8800
Nokia 8800 keeps switching off saying battery low.
sadly FIXYA can not , would recommend getting a replacement (NEW ) phone
May 13, 2017 | Nokia 8800 Cellular Phone
Blackberry 8800 The screen is black. The alert light flashes red.
MY BLACKBERRY 8800 POWERS UP TO A BLACK SCREEN.
TRIED A DIFFERENT SCREEN BUT STILL SAME PROBLEM.
DOES ALL NORMAL AND USUAL NOISES FOR A WORKING PHONE, SIDE BUTTON START THE VOICE COMMAND BUT STILL CAN'T SEE ANYTHING.
SO PLEASE HELP, IS IT TIME TO LET GO OR CAN STILL BE SORTED?
Feb 25, 2009 | RIM BlackBerry 8800
Nokia 8800 discharging prob
Nokia 8800 has the worst battery ever. Its a known issue. You need to have your phone flashed at a nokia service center, and get the new 8800 battery which ships on the 8800 sirocco BL6X.
Jan 24, 2008 | Nokia 8800 Cellular Phone
RIM BlackBerry 8800 Logo
326 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
