Question about Electrolux Refrigerators
Working procedure of electrolux ekl 235 ff,it is board type,when the temperature set it is not cooling at the temperature what we have set
When temperature increase the cooling is low,when the temperature is low the cooling is high
SOURCE: Electrolux Fridge 2 Door, Electronic Panel Problem
there s three plastic boxes the size of three inches long and two inches high there,s a leak there
Posted on Apr 13, 2009
  • 4793 Answers
SOURCE: when setting fridge temperatures is low cool best?
high and low relate to the speed at which the unit will reach operating temp..low saves energy.high is for newly stored food.
Posted on Mar 10, 2010
caroldon
  • 17130 Answers
SOURCE: Electrolux DFF44 Refrigerator not cooling
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Posted on Sep 05, 2011
  • 18 Answers
SOURCE: s75400kg fridge not cooling
Suggest you try completely defrosting and restarting.
Posted on Feb 18, 2012
ouida3
SOURCE: motor not runing properly
You need to make sure nothing is blocking the vent located in the back of your freezer, by removing all items you will have a better flow..
Posted on Aug 03, 2012
Electrolux refrigerator not working properly i have change new one picture i ve attach here thou sometime it run but after few minute it stop please suggest what should i check.
Hi, have you tried adjusting the thermostat control, if the fridge is not cooling enough you can set it to a lower temperature. There will be a rotating knob somewhere on your fridge that can turn the temperature down. Sorry if I appear a little confused, the fridge is supposed to stop after a few minutes of cooling, it should not be using the compressor all the time.
Maybe lowering the temp will soet the issue.
Jun 15, 2015 | Electrolux Refrigerators
I have a eob6630 Electrolux cooker. Top element / bottom and work ok. But oven cuts out approx 20 mins when cookin. Then switches off. But comes back on when cools. Approx 20 mins. Can anyone advise about...
From my experience the most common reason for this failure is a thermal switch for cooling fan. It is located on the upper side between the wiring and its function is to switch off the cooling fan when the temperature drops even though the oven is already turned off. If the cooling fan does not work then it will increase the temperature on the cabinet and the main temperature limiter will switch off the oven.
Dado
Jul 01, 2014 | Electrolux Ovens
My electrolux dff 44 high temprature light is on regularly on and the cooling is slowly slowly low
Good Afternoon Friend,
I understand that your Electrolux refrigerator, model# DFF44, has the high temperature light on regularly, and it is not cooling as it should. In researching your model number, I have found that it was manufactured in Argentina. I suggest resetting your refrigerator, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Give your refrigerator 24 hours to stabilize at the set temperatures. If this does not work, I suggest contacting the manufacturer. Hope this is helpful.
-Best Regards-
WP
Jun 15, 2014 | Electrolux Refrigerators
Kenmore model 795.71306 refrigerator is displaying an ER FF code on the frigerator temperature control
This error code Er FF indicates a problem with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. Sometimes this procedure corrects the problem and sometimes it does, for only a short period of time. Usually in this case, the main board will need to be replaced.
Here is the board to order.
Dec 03, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
Ive brought a new gaming rig, as follows CPU: Athlon II X2 240, 2.8Ghz MBD: Biostar TA770E AM3 / DDR2 / SATA RAM: 2GB DDR2 800MHz Case: CoolerMaster Elite 330 PSU: WinPower 450w One 300gb Sata drive One...
These new graphics cards pull a lot of power from the power supply. I know you didn't start off having this issue but given the symptoms you are experiencing I'd take a closer look at the power supply and perhaps replace it with a 650 watt or better.
Nov 16, 2009 | Acer Aspireā„¢ T180 PC Desktop
Apr 04, 2009 | Electrolux Refrigerators
Electrolux icon Stainless Steel Temperature issue
ok you have a defrost problem the freezer does all the cooling for all the unit both sides give me a few and ill give you the procedure for finding out which part needs to be replaced
Feb 20, 2008 | Electrolux E23CS75DSS Stainless Steel
Washing Machine Service station
Company:EKL Appliances Limited (not a subsidiary of AB Electrolux)Address:Global Business Park, Tower-A, 3rd Floor, Mehrauli - Gurgaon Road, Gurgaon - 122 002Tel:(91)-124-280-3250/280-3260Fax:(91)-280-3292 Got Backup?
Feb 10, 2008 | Electrolux EW1000i Front Load Washer
Refrigerators Logo
67 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
