Question about Mercedes E-class Pillar Posts Trim Set
How much does it cost to fix mercedes e350 gas gauge is not working
The gas gauge says full but then the gas tank is empty. the gauge is not working. how much does it cost to fix? How do you fix this? thanks. Melina.
    Problem Solver:
  • 14 Answers
The cost for the new part is relatively cheap, the labor will vary, but to fix it it involves dropping the tank down, unplugging and removing old putting in new, can be time consuming, prob have to replace tank straps, then you gotta get to the back of the gauge cluster and that can be tedious and time consuming too. easier and cheaper to estimate gas usage or just keeping the tank full-
Posted on Dec 01, 2013
The gas gauge for the front tank on my 1992 F150 is stuck past full
You probably have a ground wire not making contact to ground on the front tank sending unit. OR the sending unit itself inside the tank is faulty. Either way, when a gas guage goes to full all the time (empty or full), this indicates that NO ground is available for the sending unit.
Apr 02, 2013 | 1992 Ford F150 SuperCab
Gas gauge reading empty but gas is in tank
There is a sender unit failure. Likely it would need to be replaced.
Jan 12, 2013 | 2008 Mercedes-Benz Mercedes Benz C Class
My gas gauge is stuck on empty, how to fix
if your gas tank is empty of course the gauge is empty,but if the gas is full and the gauge still empty all you have to do is to check the float valve inside the gas tank maybe it is stuck.Or need to change if necessary.
Jun 19, 2011 | 2002 Buick Park Avenue
1987 ford e350 gas tank filler pipe had a ping pong sized ball inside. was this attached to something else? gas is coming out of the filler when you run the engine. what is stuck in there? do you have a...
Does your fuel gauge work properly? If not, the "ball" could be the float from the gauge sender. If the gauge does work properly, then you may have foreign objects in your gas tank. If so, then you should remove the tank (preferably when it is empty) and clean it (and the filler tube) out thoroughly.
Aug 21, 2010 | 1987 Ford F 350
Fuel gauge issue
Hello. Before getting involved in real repairs, dump a bottle of fuel injector cleaner in your fuel tank. It may clean your sending units enough to get them working again. The chances of success are only about 50%, but the cost is very low. Redline, Chevron, and others make good fuel injection cleaner.
Jul 20, 2010 | 1996 Mercedes-Benz C-Class
I have a 2000 ford e350. the fuel gauge always reads full.
the floater is stuck drop the gas tank and try to fix it or replace with new.
May 09, 2010 | 2002 Ford E350
2004 saab 9-3, gas guage shows empty, tanks is full. Fuse?
this problem is caused by a defective gas gauge sending unit, it is located inside the gas tank, u must remove the gas tank to replace the part
Jan 19, 2010 | 2004 Saab 9-3
Gas gauge is not reading correctly. Shows a full
the problem is caused by a defective gas gauge sending unit, this part is located inside the gas tank, you must remove the gas tank to replace it.
Dec 02, 2009 | 2002 Cadillac Deville
Mercedes E-class  Pillar Posts Trim Set Logo
265 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
Timllfixit
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
