Question about Microwave Ovens
How to get access to change the bulbs on a he6tix hood hotpoint
I don't want to break anything so can you tell me how to get access to the bulbs so that i don't break the plastic cover
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Hotpoint hood microwave combo/ since changing
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 27, 2009
How to change bulb in whirlpool gold microwave
If your owner's manual does not address it, it's not meant to be user-accessed, so you will need to remove the outer cover to access and change the bulb.
If it's an over the range model, you may have to remove it from the wall.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 15, 2011 | Whirlpool Microwave Ovens
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
Hood light does not work or vent hood fan
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Nov 06, 2011 | Hotpoint RVM1435 Microwave Oven
Hotpoint microwave light won't go off after I changed the bulb.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
Or you can buy and install a new smart board from the Pros here.
Oct 12, 2011 | Hotpoint RVM1435 Microwave Oven
I can not find a model number on my microwave but I know it is 800 watts/convection. Can you please tell me how to change the light bulb - I have removed the glass covering but cannot see how to access...
I would browse the manufacturers web site until you find your mode.
The bulbs are normally accessed from either an inspection cover in close proximity to the lamp or by removing the outer cover.
Hope that helps
Dec 23, 2010 | Neff H7871 Convection/Microwave Oven
Hotpoint hood microwave combo/ since changing lightbulbs in hood, fan and lights don,t work even though read out states they're on. Microwave still works,
William E. Miller
prototech@usa.net
Dec 27, 2009 | GE Microwave Ovens
The hood light blew and I replaced it. It worked
The cause could be anything from defective bulbs(least likely, to a bad bulb socket or vibration during operation. A voltage measurment at the bulb will tell you if it is getting too much.
Eric
Dec 24, 2009 | Microwave Ovens
Light bulb going out
Unplug your unit then you have to remove the cover from the microwave. Just remove the screws that are around and in the back if there are any. once you remove the cover you should have access to your bulb. Befor removing the cover just inspect the inside of the oven to make syre that ther is no access plate in there to remove the bulb. I hope this helps. Don,t forget to rate my answer, thanks.
Feb 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
The light inside my microwave JVM1650BH05 has burned out.
you have to remove the screws from back and bottom and pull top of microwave off. Then you will have access to the bulb. Don't worry, you won't break anythiing
Jan 30, 2009 | GE JVM1630 Microwave Oven
I'm trying to remove a Hotpoint RVM58003. I removed four long bolts from the top but it does not move. Any help on what I need to do to remove it? Dan
The Hotpoint RVM58003 (circa 1984) cannot be lifted off a hanger after the four top screws are removed because it doesn't have a separate pre-installed hanger like newer units do. The rear mounting screw holes are part of the outer frame of the unit, which requires removal of the Microwave sub-assembly of the Hotpoint RVM58003 to expose the outer metal frame and the array of pre-drilled rear mounting holes before the rear mounting screw(s) can be accessed and removed. Based on my recent experience removing a Hotpoint RVM58003 Microwave Hood from 1984 it appears the unit was originally installed this way too. Please note that this is a very involved process. Basic steps are: 1) Unplug AC power to the unit, or turn off the circuit breaker. 2) Remove the top plastic grill over the door and control panel (2 screws). 3) Next to the grill screws remove the larger left/right screws holding the Microwave sub-assembly in. 4) Drop down the hinged light bulb/air filter cover panel (mine had 7 screws). 5) Remove the small metal cover plate on the right under the control panel. This exposes the Microwave sub-assembly electrical connector. 6) Disconnect the Microwave sub- assembly connector. 7) Carefully pull the Microwave sub-assembly out of the frame and set aside. You may need to fish the power cord through the cabinet or unscrew the power cord terminals. NOTE: this is best done with a helper because this sub-assembly is about 25-30 pounds. 8) Once the sub-assembly is out the rear plate is exposed and the rear mounting screws can be removed. I found that the GE/Hotpoint Owner's Manual does not have installation instructions. Neither does the GE web site, they only have the Owner's Manual. For more specific help and instructions I suggest calling The GE Answer Center at 800-626-2000 or hiring a professional installer experienced with this older style Microwave Hood.
Jan 23, 2009 | Hotpoint JE740WY/GY Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
