Question about Elna Sewing Machines
Elna supermatic reverse lever permanently in reverse
The reverse lever remains on RHS. It can be moved to the left but will not remain there.
SOURCE: Elna threading and reverse instructions
Hi
I have a Primula 310
The reverse is located in the middle of the stitch length dial, you press in the button whilst you reverse.
When threading up any sewing machine make sure the foot is 'up' as this opens the tension disks and the thread goes between. when you lower the foot the discs close around the thread and add the tension.
Hope this helps
Posted on Nov 01, 2007
SOURCE: have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Posted on Apr 09, 2009
  • 1116 Answers
SOURCE: do not know how to thread bobbin on elna
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
Posted on Feb 21, 2010
Testimonial: "Immensely helpful thankyou very much"
SOURCE: service manual elna 722010 sewing machine
www.whitesewingcenter.com has the manual for an Elna 722010.
Posted on Mar 27, 2010
Tally Girl
  • 1133 Answers
SOURCE: I was given an Elna Supermatic 722010 and am not
A link to a supermatic manual is here
http://www.arizonaexpressionz.com/elna_instruction_manuals/Supermatic.pdf - I suggest you download this and print it out as this machine is over 50 years old now and manuals are scarce.
Disengage the clutch by holding the outside of the fly wheel and turning the inner knob of the wheel towards you.
You need to take the thread from the spool across to an eyelet on top left, then back to the bobbin winder, up through a hole in the top of the bobbin and hold the thread tail. Flick the bobbin across against the stopper. Now press the presser foot or knee control to start the motor. Hold the thread tail until youve got coverage across the bobbin enough to hold the start, then stop winding and cut the thread tail with scissors. Now continue winding but put the handle of your scissors on top of the thread spool to stop it bouncing and ensure your thread winds smoothly and under tension.
Watch the bobbin fill and give the thread a nudge to fill top and bottom as well as the middle evenly, you want a nice even wind. Fill to 3/4 and stop, flick bobbin back off the stopper, then cut the thread. Remember to re-engage the clutch by reversing the first step.
This is a lovely heirloom Elna machine - you need to thread the bobbin as the manual describes and get the thread into the tension spring. Please read the manual information on oiling too, this machine needs to be oiled on the red spot locations every time you use it according to the manual, use good quality clear sewing machine oil for this purpose.
Posted on Apr 13, 2011
The stitch length lever is stuck on my Elna Supermatic
the best solution for the sewing machine is to take the machine
to a sewing machine shop & have it serviced, to find out why it's
stuck in position A. that way you will know wether it's needs cleaning
& new oil & grease or if some part is damaged or not.
Jun 02, 2012 | Elna Sewing Machines
Walking foot for 1963-1964 elna supermatic
try a elna dealer
sewingpartsonline.com
sew4less.com
May 15, 2012 | Elna Sewing Machines
Where to get a user manual for Elna Supermatic 722010 sewing machine - vintage 1963-1964
Hi Beverly,
My suggestion is that you join up the Yahoo group called "Elna Heirlooms" you'll find lots of very helpful fellow supermatic owners there and probably what you are looking for too. Here is one page from the manual for threading the bobbin into tension, once you've mastered this on the Elnas, its the same for all the Swiss ones.
Yes, top threading is important, you need to get the thread into the tension discs and also the take up lever. Have you cleaned out the tension discs too? these do get gummed up with fibres and dye particles sometimes. Just turn tension down to zero and "floss" between discs with the selvage edge of a clean piece of waste cotton fabric.
Might see you over on Yahoo, several of the members there are really knowledgeable on these great machines.
cheers
Tallygirl
Oct 13, 2011 | Elna 2007 Mechanical Sewing Machine
My "new" elna type 722010 only sews in reverse.
What is the stitch length lever set to (4 in the diagram below)? these models have a lever that slides from positive to negative (ie) reverse, so you need to set it to the positive area, between 2 and 3 above zero. If you move it below zero then it sews that stitch length backwards.
If this machine is new to you, you might want to join the yahoo group called "Elna Heirlooms" there is lots of helpful members who share info on these old machines there.
Jul 15, 2011 | Elna Sewing Machines
I HAVE A ELNA SEWING MACHINE MANUAL AND CAMS AND FOOTS TO FIT OF ELNA SEWING MACHINE BOUGHT 52 YEARS AGO UNFORTUNATLEY I DO NOT HAVE THE SEWING MACHINE I LEFT THAT WITH A REPAIRER HERE IN ADELAIDE AS IT...
I would love to take these off your hands as my Mum has an Elna Supermatic that was her mum's. Could you email me on cwrogers@tpg.com.au, I'd be happy to pay postage to ship, I'm up on the Gold Coast.
thanks
Carolyn
Mar 17, 2011 | Elna Sewing Machines
The feed isn't working on my Elna
I'd suggest that you join the Yahoo user group for Heirloom Elnas, the members are very helpful and share images of manuals and their experience. You should be able to download a copy of the supermatic manual from here once you've joined up.
Is your supermatic a green model like this one?
or there is a white with blue top supermatic from the Star Series, it looks like this
If its the star series, you'll see above a round knob with red and black numbers, this is the stitch length dial. Red is reverse, black is forwards. The lever just to the left is the stitch width lever and the round dial to left again is the needle position dial.
If its the green model then the dials and knobs are in different places but they work in a similar fashion.
Good luck wiht your machine.l
Mar 04, 2010 | Elna 1010
Tune up/repair sewing machine
Get some WD40 and oil all thge moving parts that you can see but very lightly.
Oct 27, 2009 | Elna Sewing Machines
What bobbin size for elna supermatic 722010 Can I purchase metal bobbins for this machine at a Joannes? or ? Is there a staner bobbin number or size to ask for?? thanks@ The Elna I have came with ONE...
Elna Supermatic 722010 is a very vintage elna and would take the metal 7 hole dished bobbin like this.
Don't try to use any other bobbin in it, and always load and wind with the holes on top.
You can still buy these; one supplier is sewingpartsonline, here is like to the item
http://www.sewingpartsonline.com/bobbins-elna-426000-10pk.aspx
Aug 17, 2009 | Elna Heirloom Edition 6005
Have a 1970's elna su supermatic but cams don't work
I hope this helps!
Mar 11, 2009 | Elna 1010
Sewing Machines Logo
169 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
