Question about Westinghouse WWSS2601KW 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door
Icemaker is not making ice in westinghouse model number WWSS2601KWO
Ice maker... its makes the ice but then doesn't dispense it the whole way.. its like it gets stuck sitting there and doesn't want to keep rotating, i have to lift or "reset" the wire ... its a model # M1
Good Afternoon Sean, thanks for your inquiry!
I understand that your icemaker is not dispensing ice and it gets stuck rotating. You have provided me with a model number of M1 and I was unable to locate any information on that icemaker. May I have the model number of your refrigerator? You can locate the serial tag (which lists your model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
Mar 15, 2015 | Frigidaire Ice Maker / Icemaker 5303918277...
How to fix Frigidaire icemaker
Hello Friend, that's a great question!
May I have your model number please? The serial tag (which lists your model number) is normally located inside the cabinet, on the left side wall. Also, is your icemaker not making any ice or dispensing ice? With this information I can provide you the correct instructions on how to fix your icemaker and/or some basic troubleshooting tips. Best - Z
Aug 19, 2014 | Frigidaire Refrigerators
How do you remove icemaker to check if water tube is frozen?
the ice maker is finished. get the ice maker model number and refrgerator model number and buy/ install a new one. It would be a good idea to replace the electric water valve to the ice maker as well.
Feb 07, 2014 | KitchenAid Architect Series II KSRJ25FXMS...
I have a Kenmore 55602400 Coldspot and the icemaker has stopped making ice. What do I need to do to fix it?
The model number you listed is for an air conditioner. Please check inside the refrigerator for the model number?
Oct 15, 2012 | Kenmore Refrigerators
Ice maker makes knocking noice
It would depend on the model of your fridge. Most fridges, you would just need to change the icemaker, but if it is a whirlpool or kitchenaid, you can just replace the module on the front of the icemaker (part number 8201515)
May 19, 2012 | Electrolux Refrigerators
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICEMAKER ON WHIRLPOOL ED2GHGXMQ
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 14, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Will not make ice but will give water model number is gss22wgmb ww
check the dual water valve one side is for the icemaker the other for the water in the door
either a water valve issue or a ice maker problem
if the valve checks good check the line off of the valve to the ice maker you should be able to blow thorugh the line to the ice maker if you caint blow through the line it is frozen in the freezer behind the icemaker and will need to be thawed
if you can blow though the line to the icemaker
replace the icemaker
May 09, 2008 | Refrigerators
Westinghouse WWSS2601KW 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Logo
44 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
