Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Amana ptac how to set constant fan - Amana PTH123B25AJ Heat Pump Air Conditioner
oscarn
  • 109 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
  • 49 Answers
SOURCE: Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
Posted on Nov 18, 2007
  • 54 Answers
SOURCE: 2 problems.. AC Comp cuts out. And Fan will not stop.
Unit#2 -Sounds like the contacts on the master switch are welded closed or the switch is broken, Replacing the switch should fix this unit.
#1 is a little more difficult to diagnose. The compressor is being taken off line by a circuit that protects the compressor from damage either; 1- liquid refrigerant getting back to the compressor which can be caused by something as simple as a clogged return air filter or evaporator coil on a heat pump or 2- overload situation caused by a bad condenser motor or a clogged condenser coil. The first thing you need to do is clean both coils and replace the filter,. Then check to be sure your getting good airflow across both coils. I think it's most likely an airflow issue I hope this resolves the problem GL!
Posted on Jun 12, 2008
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
  • 3 Answers
SOURCE: ptac not heating
the board or the heater need to be replaced
Posted on Jan 06, 2009
What does it mean when it indicates stop?
Wow, a talking AC?
How to Reset an Amana PTAC - YouTube
? 0:55
www.youtube.com/watch?v=D4SQfFChiKY
Mar 28, 2014 - Uploaded by Total Home Supply If you ever need to reset your Amana PTAC this simple guide will ... HVAC AC Blower not working, troubleshooting Fan Control board, Fan not ...
Aug 21, 2015 | Amana Heating & Cooling
Where can I find a troubleshooting manual for the DS01E amana t-sta?
http://www.amana-ptac.com/Portals/3/PTAC/PDF/DigiSmart%20DT%20DS%20DD%20Wireless%20EMS%20Installation%20Instructions%202010.pdf
Feb 19, 2015 | Amana DS01E - DigiStat Thermostat with...
Amana PTAC will cool but fan will not go up in speed
Change the thermostat wire , if not change your board.
Jun 02, 2012 | Amana PTH123B25AJ Heat Pump Air...
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
Jun 19, 2010 | Amana PTH093B35AM Thru-Wall/Window Air...
Amana ptac constantly freezes changed board with dsuko1c kit
in heating mode find sensor located on coil follow to board connection usually 24v and dft terminal jump out with a wire and jump test pins if goes into dft then sensor bad if not board
May 11, 2009 | Amana PTC093B50AJ Electric Heat Air...
Ptac not heating
Dec 23, 2008 | Amana AAC051FRB Air Conditioner
Jun 11, 2008 | Amana PTH123B25AJ Heat Pump Air...
Ptac fan keeps blowing
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
221 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
