Question about Frigidaire Affinity ATF7000E Front Load Washer
My front load washer affinity pauses 3 or 4 times during a cycle
Why would this happen, i tried unplugging the machine.
  • 2 more comments
  • meelifluous Jan 23, 2009
    Brand new washer. First load in. It paused at 28 min (on 30min cycle), I hit start and started again. Then it paused at 26 min, so when I went down because I thought it was down it had shut down again.
  • mojean Feb 02, 2009
    Thanks "onthejob", I finally tried what you suggested. The washer paused right from the beginning and after, so it was during the fill up cycles. I turned the tap on a bit more to allow more pressure and presto, no more pauses.Thanks again, much appreciated.
  • Tim Toolman Mar 25, 2009
    I have the same problem with the Frigidaire Affinity. But it doesn't do it all the time. About 40% of the time it pauses during washing. Usually during the water filling cycles. And when I hit the start button again, to resume. It starts filling the water, but at the same time, I can hear water trickling down the drain. So, do I really have a water pressure problem, or is the washer malfunctioning?
  • jlmathewstx
    jlmathewstx Apr 11, 2012
    I had the same issue for me it was a filter that needed cleaning, once we cleaned the filter good as new
  • 640 Answers
The unit is waiting for something,,,like water ,,,or a slow drain..you must see where the unit is ,in the cycles,,and make sure that action the unit is trying to do is able to do...onthejob
Posted on Feb 01, 2009
  • onthethejob1
    onthethejob1 Feb 02, 2009
    thank you onthejob,,bookmark me
Reads "empty tray". Tray is empty, clean, and dry. We have tried unplugging machine and resetting, The machine has not worked in 3 days.
The tray may have some redidual soiling around the electrical contacts at the back.
Try cleaning the contacts and see what happens.
Oct 01, 2010 | Jura Capresso Impressa S9 Coffee...
Machine stopped working but light is on
I've had that happen a couple of times, try unplugging the machine for a few minutes then plug it back in a see if it works
Aug 13, 2010 | Husqvarna Huskylock Computerized 905
Light stays on eight
I had this happen recently due to a power outage. I found my manual and to reset you need to unplug the unit from the socket it self AND the back of the machine. I tried just unplugging it from the back of the machine and this did not work. When I did BOTH things, the machine reset. At least give it a try...
Jan 16, 2009 | GE 29875GE Digital Answering Machine
Canceling a transmission after I have sent it to the sewing machine
Start from the beginning and get the machine ready for embroidery. I found I had not put the feed dogs down when it happened to me
Nov 02, 2008 | Singer CE-200 Quantum Futura Computerized...
Door locked & nothing happens Whirlpool duet wfw8300sw01
hi there,
sounds like the machine has no power at all.
there was no need to break the lock.
unplug the machine
take off the console
check connections from the touchpad to the CCU board
make sure nothing is corroded, burned, bent or pinched
unplug and replug the wiring harness
plug the machine back in and try it again.
let me know if this works.
Sep 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Washer Model WJSE4150B1WW
You may try a couple of things. 1. unplug the machine overnight and then try it. 2. unplug the machine, take the backsplash loose where the timer/control panel is located. check to make sure that you don't have any rodents, bugs or roaches in the timer/control panel causing you problems such as chewed up wires or dead bugs in the control panel. If this is the case clean out the control panel and or repair any wires.
3 Replace control panel.
Jan 02, 2008 | Washing Machines
Breadman TR555LC
Yes, that just happened to me. The book says E01 means the Breadman is too hot - remove Bread Pan with ingredients, and wait until the Breadman cools down - about 20 min - before preparing a new loaf.
E02 means the Breadman is too cold. Unplug machine and allow it to heat up to room temp. and try again.
For E03,4,5,8 - unplug the Breadman and contact customer service.
Nov 30, 2007 | Breadman TR555 Deluxe Rapid Cool Touch...
Frigidaire Affinity ATF7000E Front Load Washer Logo
992 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
