Question about Philips Magnavox DVD/VCR Dual Player
Trouble w/ sanyo VCR after connecting DTV converter to TV
I need to understand how to hook up VCR once DTV Converter is connected. When I turn on VCR, TV screen goes blank; however, I do not have any audio/video from the VCR. I have tried several combinations with red/white/yellow cables. Any help in understanding how I need to connect these cables. Thanks. I think I'm confusing what goes 'in' and 'out' to where. Any help will be appreciated! Thanks. Carmen
My garage door a craftsman 1/2hp 1999 Model. Opens without us opening it.we Donot have the Manual is there anywy we cn get it.
thanks
Patrick
Posted on Jan 18, 2009
I need a 2004 Sanyo T V No remote,hooked to dtv converter box,what menu settings do I use(flat screen,fat back)
when all connected both colour cables and antenna in and out of the desktop box and TV correctlyand both turned on
almost every DTV box will start its menu automatically
and follow the menu promps
chose auto search the channels
Apr 30, 2016 | Sanyo Televison & Video
Hook up analog vcr to hd tv
You must have a converter box for the tv and for the vcr. Set the vcr to receive chanel 3 and set the converter box to the digital chanel you want to record. Put a splitter on the antenae out and route one to the tv converter box and one to the vcr converter box. GOOD TO GO.
Apr 11, 2009 | Sanyo Televison & Video
Taping digital onto a vcr
You'll need to connect the VCR to the converter box and then connect your VCR to the TV. ou can get a diagram showing how to connect everthing at www.dtv.gov; there is a section with publications that has a document on how to hook up your VCR to tape the show your watching or watch one show while taping another.
Mar 14, 2009 | Insignia Digital-to-Analog Converter for...
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Wish to record on analog VCR and not affect digital TV reception
I don't think it will affect the digital TV reception, but if you try to use the VCR built-in tuner it is still analog and you won't be able to record digital channels that way. If your digital TV converter has video-out and audio-out connectors, then you can connect those to the corresponding connectors on your VCR to record.
My Zenith VCR is not working with the digital converter box
When the VCR is "off" the converter signal should go right through the box, which you say it does. Then, when you turn the VCR "on" the picture disappears. That, so far, how it should be. To get your picture back while the VCR is "on" you must set the VCR to "receive" channel 3, and use your new converter box to change channels...accordianman
Dec 16, 2008 | Televison & Video
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Philips Magnavox DVD/VCR Dual Player Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
