Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman 90% gas furnace control board stolen
Replaced board- furnace will lite ,just when the blower fan is about to start burners go out.Checked high limit-ok,checked flame sensor-ok(bypass w/jumpers)---Sometimes it will get to where the fan comes on and everything will run for about 4 min.s ,then valve will shut-off again--- Diagnostic code flashes constant after this---reads--twinning-24 volt out off phase
  • lazgo Jan 20, 2009
    Thank you... problem was in the 120v...wire from brkbox had grd wire going into a terminal box ,but wires from trml box to furnace had none...replaced wires w/one that had ground ..Bingo success....New boards are more sensitive....
  • 146 Answers
Make sure high voltage wiring is correct
Posted on Jan 19, 2009
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
BGU10016A BLINKS CODE 9
www.repairclinic.com/Shop-For-Parts/a36b383/Coleman-Furnace-Parts
Nov 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
Coleman h 90 gas furnace will not start up when thermostat is turned up
The gas valve is not lifting hence no gas flow , check pressure switch if fitted jump out thermostat see if it lights ,
Jan 10, 2013 | Heating & Cooling
Hi my miller gas furance burner comes on but the fan does not come on , then the burner goes off soon after ward. any idea's ?
sounds like the fan motor maybe bad. take the fan door off and see if you can spin the fan. if not the motor will need to be replaced. if it does turn you will need a volt meter to test the input voltage.jumper the fan door switch and lite off the furnace.with the volt meter on the high speed wire you should see voltage in about 60/90 sec. if you have voltage once again the fan motor is bad. if no voltage your furnace is cycling off on your t-stat or your board is bad.
Mar 22, 2011 | Heating & Cooling
I have a coleman furnace it comes on the electric igniter glows red the gas comes on then the blower starts and the fire goes out it gives 2 different code for this 1 is ignition failure and the other is...
I would have the ignition control board replaced. That is what tells the gas valve to come on and if there is flame or ignition it will keep the gas on if the flame sensor gives the board a signal that the burner is lite. By you shuting power off and on to the furnace it resets the board and it will go through its cycle again.
Feb 10, 2011 | Coleman Heating & Cooling
I have a Coleman Evcon gas (propane) furnace. When the t-stat is switched to heat the furnace heats up but the blower will never turn on. The unit then shuts down and tries to cycle again. I have replaced...
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Jan 18, 2010 | Coleman Heating & Cooling
Blower opperation on gas furnace
How long does the burner stay on before the limit takes it out. The board has a delay for the fan in heat and it may be to long. If your unit had cycled on high limit to much it may have a bad limit switch. The limit is so low it cuts out before the fan has a chance to come on. See on the board if has an adjustable time deley. Should 30 60 90 set to thirty. Keep in touch rus
Dec 12, 2009 | Heating & Cooling
Blower fan runs to long
ther might be dip swiches on the circuit board you might have to change
Dec 17, 2008 | Honeywell Power Humidifier: Furnace...
Blower works but no heat
If in fact you have the above listed furnace, you do not have a pilot but electronic ignition. You will need to remove the front cover on the furnace, tape down the door safety switch and then have someone help you by turning up your thermostat to a very high setting. Watch and listen inside the furnace. There should be some blinking going on at the control board followed by a small blower fan starting up. Then after 10-15 seconds there should be a click followed by an orange glow viewed thru the viewing window to the burner section. In a few seconds the gas valve should click and the burners will ignite. There is a safety switch that will sense flame and then keep the gas going to the burners. If it does not sense it, it will shut it off within 10 seconds. If all is well so far, your blower will turn on in about 90 seconds after flame. There is a diagnostic code chart on the back side of the access door if you get an error code (blinking) on the control board.
Always check little things like air filter, condensate drain and broken or loose wires.
Nov 05, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
250 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
