Hi there, my Mag LCD 2209A monitor goes blank very often, warranty just expired last month. It seems like the power supply unit needs to be replaced, however, I cannot open the case. There are no screws whatsoever on the case. I've taken off the large label from the back of the case, was hoping to find any evidence of screw, but I didn't find. I'll appreciate very much any Idea on how to open this case, in order to replace the power supply unit.
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Mag Innovision 700P LCD Monitor
I hope it's SMPS power supply is broken.
You didn't mention any symptoms but if it just refuses to turn on you are probably right.
One word of caution; finding a bad IC, a failed transistor or diode may only be a sign of the illness. Check every electrolytic capacitor in the supply; there are thousands of failures of some values and if you find some failed, hope for & check the date codes on the replacments and try to avoid the period of 2003 to 2006. There are millions of capacitors from many different companies that have defective electrolyte in them.
Posted on Oct 10, 2008
bammbammfran
  • 159 Answers
SOURCE: DELL LCD monitor E151FPb turn white
If the screen is all white light then you can have a number of problems.
One could be a bad video board, the next could be a simple loose wire from the video board to the back of the lcd screen OR a simple blown fuse on the back of the actual lcd screen can cause the same thing.
Snaps are all sround these things and can be really stubborn at times. Best to start the bottom first then work up each side to the top.
Something flat, thin and with a decent sharp edge on it will help. A pocket knife held parallel to the joint between the front and rear plastic works, you can also sharpen the edge of an old credit card with a file (nail file works) This isn't as strong as a blade , but safer if you slip !!
Fran
Posted on Oct 11, 2008
  • 555 Answers
SOURCE: How to open (remove back) Omnitech Vw19B LCD Monitor
You are right about the problem on the flourescent, but the issue is caused by the mosfet transistors. You need to use a flat screwdriver to pry the back of the display until you get this open. Start from the bottom side because some damage will be left on the plastic.
Posted on Apr 15, 2010
Samsung 22inch lcd monitor goes blank after 1min idle system.
Hello sir, I have samsung 22in lcd monitor and nvidea fx5500 card. since last more than 6 months, my monitor goes blank If system remains idle (means I don't move mouse and don't touch keyboard) for 1 minute. After monitor goes blank I have to move mouse to brink it back to on. The power led keep on during this problem. I tried everything including power options in windows but could not fix it. Is it bios setting to be checked or could it be windows bug? Please help
Mar 23, 2010 | Acer X193W LCD Monitor
The moniter went all black and the power button on the moniter is flashing on and off
Please disconnect the monitor from the PC and if still the monitor is blank then monitor is defective because when you disconnect the monitor from the pc you should see a message on the screen about signal like no signal etc..
Jan 29, 2010 | Dell Computers & Internet
Dell Monitor Blank
It seems the problem my not be to involved.
1st. Did you take the monitor apart.? If so, you should back track and find what you had missed.
2nd. If you had not taken the unit apart after the power surge, you will more than likely have to, in order to repair your monitors problems.
3rd. This will most differently require the removal of power supply and the replacement of 5 to 8 Capacitors.
4th. If you are not experienced in the replacement of electronic items on a printed circuit board, Please do not attempt this repair.....
3rd. If the unit has any kind of warranty, you may want to pursue a warranty repair.
Do Not Tell Reps. That You Had A Power Surge.
No electronic equipment is covered under Power Surge Faults.
If you do feel confidant in the removal and replacement of these items, please reply to me here or at my website and I will explain in detail, how to get to and remove supply and what to look for in repair.
John Ray
john@johnrraycomputer.com
Jun 16, 2009 | Dell E173FP 17" LCD Monitor
MAG Innovision LT2219WDB monitor will turn on -picture up clear as ever and 2 seconds screen goes black, turn it on and off screen comes up clear as always and 2 seconds goes black. will not keep the...
I have the same problem with a customer's monitor (LT716S); it turned out to be damaged power supply board. As I understand it, MAG has a 3 year warranty on parts, will probably charge you a flat labor fee plus shipping. If you do not have your purchase documentation for warranty, dump it and replace. If you can, then you may wish to have it repaired.
My customer replaced theirs; I am trying to purchase replacement parts to repair...good luck.
Feb 24, 2009 | Computers & Internet
Dead monitor,,,,,,,,,,,,,,,,,,,lcd viewsonic
If the power supply is not wqrking then it is the invertor unit that has dies.
Replace the monitor is the best advice- If it that recent out of warranty may be worth contacting 'viewsonic to see if they will discount you one.
Jul 19, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MAGinnovation LT916s
Hi...there,
It's seems you need to replaced a new backlight inverter. Check this site out...@ www.3rd-rocks.com
maybe have what you needed... Have a nice day!
Jul 08, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag Innovision LT576S monitor goes blank after 2 seconds
I would think that the monitor is the issue, especialy that in safe mode it still does not function properly!
The fault with the monitor may be in the scan amplifier circuits, and or the power supply.
When I used to service these, I found many times that there were defective electrolytic capacitors in the scan amplifier sections and the power supply that gave problems.
This type of repair is time consuming, and when out of warranty it may not be worth the cost.
I would be seriously considering an LCD monitor.
Jerry G.
May 19, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
Black screen
Hi
my problem was fixed by viziks from FixYa dated Sep 12
replaced 2 push pull transistors 2sc5707 in high voltage transformer circuit
Transformer used for backlight lamps
Both monitors now working THANKS VIZIKS
Feb 09, 2008 | HP vs15 15"LCD Flat Panel Monitor
Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
Hp flat screen monitor
It's probably your dc power supply.
Mine would blank just 2-3 seconds after power-on.
I pulled this monitor out of the garbage - someone threw it away. I found any old 12vdc power supply I had laying around (1 from an hp scaner 1250mA, another rated at 600mA) neither could supply the current (amps) required to run the backlights, therefore backlights shutdown, monitor goes blank--monitor stilled powered on, but black.
I tried all of the disassembly, re-solder various solder joints on the LCD Inverter board and removing the heat/magnetic shield from inside the back cover of the monitor. Nothing worked.
I bought a Segate 80gb external hard disk drive that came with a 12vdc power supply, looks like a typical laptop power supply, rated at 3A (3000mA). Plugged it to the monitor, it powered up, and it works flawlessly.
Oct 19, 2007 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
