Question about Motorola Mobility CITRUS Smartphone
My motorola citrus doesnt charge all the way
Everytime i go and charge my phone the usb connection always pops up and then when its charging and its full battery and i take it off the charger it doesnt hold the charge.
  • 3 Answers
It because if you looked where you charged your phone it might be dent you might off but your charger and click moving i know that because in my droid razer i did the same and know it wont charged that's why i using my motolora phone
Posted on Jan 19, 2013
CompuGuy44
  • 432 Answers
SOURCE: Battery won't charge
I have the same phone and it flashs every now and then when its charging but it charges and works fine. Is yours charging?
Posted on Jun 25, 2007
SOURCE: Motorola E815 - Battery Charger
The E815 has a very poor design on the charger port. The cleaning that Solution #1 referred to is that Verizon cleans the contacts of both the phone and the charger using rubbing alcohol on a toothbrush to clean both the phone contacts and the charger contacts. I have to do this once a week or so to keep my phone charging. The rubbing alcohol dries quickly and will not harm the phone. Motorola has changed the charging ports on the newer phones because they recognize that they have a problem with this design. I have also turned in my phone to Verizon (twice) for a replacement. If you replace the phone be careful to record ALL your contacts because when Verizon transfers your contacts from the old to the new phone the speed dial numbers all get messed up because they start their numbering differently than you had it. I am still repairing my speed dial numbers. Hope this helps.
Posted on Sep 07, 2007
  • 221 Answers
SOURCE: Motorola W375 won't charge online!
You'll need pc charging drivers to charge your phone with a pc and a USB cable, you can get the driver at the motorola website.
hope this helps.
Posted on Mar 31, 2009
walesarumi
  • 6993 Answers
SOURCE: charging problem
I think the charging port is bad and this could be as a result of factory error since the fault is not from you. The phone restarts probably because the charging ports is bridging.
I will advice that you purchase a desktop charger that will enable you charge the battery seperately and when the battery gets full, you insert it into the phone. You could get another battery so that while you charge one, you use the other.
Or if you can look for a repairer, that will help you fix the fault of your phone.
Best wishes
Posted on Nov 16, 2009
  • 10 Answers
SOURCE: motorola razr2 v9m wont charge
My guess is that the charging port in your phone has gone bad. By holding it a certain way, you may be reconnecting it just enough to make the connection. Probably have a loose or broken wire inside your phones port. You may also see this is a problem if you try to hook it up to a pc.
Posted on Feb 05, 2010
Why won't my screen come back on after I charged it to complete?
Its a trouble a firmware/android issue. Try charging it with an adapter that doesnt have a plugable cable USB/micro usb that gets in in the adapter, but with an adapter that ghas micro usb directly.
Have the same issue with my last phone and this fixed it. Next time charge your phone before its flat/completely empty
Oct 18, 2014 | Motorola Mobility TracFone C139-4 Cellular...
Usb connection notification, what does it mean, won't go away
it is telling you the cord is plugged in and it is asking what it is plugged in to
Aug 01, 2012 | Motorola Mobility CITRUS Smartphone
My Citrus won't charge. When I plug it in I get a pop up to manage my USB connection.
hi tara martel you need to go into the serrings. next you need to go into applicationsand select applications next you ned to go into development and seledct usb debugging. and stay wake . next plig yourcharger in and now it should give you the 4 choices . tone of these choices is to charge only on your phone. you can pull the battery. it will reset the phone you will need to make sure that it is set up for charging hope this helps.
Mar 24, 2011 | Motorola Mobility CITRUS Smartphone
I lost my drivers. it s not getting connected to pc
HOWTO_Connect How to connect Motorola W375 to a Windows computer Introduction¶ This document describes how to connect your Motorola W375 to your computer in order to use it as a modem, or to administer it with Motorola W375 Manager software.
Connecting¶ To connect your motorola W375, follow the next steps:
  • Download and uncompress Motorola W375 Driver from this site.
  • Connect your W375 to your computer with its lid closed.
(You can also connect the device with its lid open, and choose "not" when it asks for permission to connect as an storage device)
  • When Windows asks you for a driver, select Motorola W375 driver folder.
This way, the next time you connect your mobile phone closed, your computer will recognize it as a new communications port and you are ready to use it with Motorola W375 Manager. If you open this "COM" port with a terminal emulation software (i.e Windows Hiperterminal) and type "AT", the mobile phone will respond you with an "OK" string.
Using it with Motorola W375 Manager¶ To use your mobile with Motorola W375 Manager, simply connect your mobile phone closed and then, start Motorola W375 Manager software.
Using it as a modem¶ To use your mobile phone as a modem, install "Standard 19200 Modem" driver and select the communications port associated to your motorola W375.
About Motorola W375 driver¶ Motorola W375 driver is basically the same driver known as Motorola USB Charging Driver. You can download Motorola USB Charging driver from motorola US support web site for Motorola W375. If you try to use Motorola USB Charging driver directly with your Motorola W375, device type will not be recognized, but if you change device ID from "USB\VID_2811&PID_0702" to "USB\VID_22b8&PID_4061", this usb charging driver will become completely compatible with wour Motorola W375 mobile phone. The driver you can download from this site, is exactly a Motorola USB Charging driver with the mentioned modification.
Dec 07, 2010 | Motorola Mobility W375 Cellular Phone
My motorola rokr e8 wont charge with usb cable on my computer
hi...
To charge your mobile with usb cable you should install a driver called as mobile phone usb driver ,if you install it you can charge your mobile through PC.
If still it doesnt charges then install the PC CHARGING DRIVER.
I will give you the website which contains the driver and the instruction below it to install the driver so that you can charge your mobile by usb
website : http://www.motorola.com/consumers/v/index.jsp?vgnextoid=3fd11e8c04021210VgnVCM1000008406b00aRCRD
thanx
Jul 19, 2010 | Motorola Mobility ROKR E8 Cellular Phone
Have blk moto razr v3a cell phone. when connected
down load motorola phone tools from www.modmymoto.com the proper drivers will load and youll be fine
Mar 02, 2010 | Motorola Mobility RAZR V3a Cellular Phone
Motorolla peble
It's Italian for "unable to charge"
Motorola phones won't always charge with non-Motorola chargers, or via USB connections.
Does it do this with a Moto charger or a generic one?
Dec 21, 2009 | Motorola Cell Phones
Where is the usb port on this phone
http://nextelonline.nextel.com/NASApp/onlinestore/en/Action/OSBrowseAccessoriesDetail?PHONE_ID=I880G&categoryRefName=Data+%26+Connectivity
solution to this problem is that the USB is on the connector
its an accessory
-->pt_accessories_en.gif Data & Connectivity for the i880 by Motorola (Choose a different phone) spacer.gif Motorola USB Charging Data Cable - Item # NNTN5405 nntn5405_l.gif Easily link your phone to the USB connector of a computer or PDA, use your phone as a wireless modem and more. The cable also features an integrated charging port so the phone can be charged while simultaneously performing data operations. The charging port can be used with compatible standard, rapid and vehicle power chargers.
Jan 24, 2009 | Motorola Mobility i880 Cellular Phone
Data transfer in motorola L6
Download Motorola Phone Tools Check my other post too.. http://www.fixya.com/support/t201850-install_java_applications_like
Sep 15, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility CITRUS Smartphone Logo
63 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
