Question about Cameras
Bulb setting on panasonic FZ 200 camera
Can you advise where to find a bulb setting on my new lumix FZ 200 camera, to permit exposures of more than 60 seconds
  • 155 Answers
SOURCE: I lost Panasonic LUmix DMC-TZ15 driver
Do you have a USB card reader? Just take the card from the camera, pop into the reader, and you can transfer your photos.
No drivers required unless using Windows 98 or earlier.
Also, the model is wrong, do you mean TZ5? You should be able download software for the camera from www.panasonic.com
Posted on Feb 09, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: How to purchase a manual for Panasonic Lumix FZ 8
You can download it for free from Panasonic here.
Posted on Apr 03, 2009
SOURCE: Panasonic Lumix DCM FS5 camera. Inbuilt Memory
delete the pictures (you should be able to upload them first)
Posted on May 28, 2009
  • 83 Answers
SOURCE: lumix fz-20 panasonic has message
Does the camera start up as normal? Is the message intermittent? When does the message appear? (i.e. when zooming, when taking a picture, etc)
Unfortunately this message doesn't have one clear meaning. Or rather, it does - it says "something is wrong with the camera". From what I noticed with Lumix cameras, lens is usually the reason for this. (e.g. if there is a bit of dirt stuck in lens gears you would end up with the same message). If it's dirt in the lens, the solution isn't easy, you either need to have it repaired at panasonic service, get a replacement lens from an otherwise defective donor camera from e.g. ebay and replace it, or alternatively dismantle and clean the lens yourself if you're brave.
On one occassion I saw this message appear due to a problem with flash circuit. Disabling the flash sorted it out.
I would recommend first trying to disable any fancy options in the menu (e.g. flash, image stabiliser, macro, etc) and resetting the settings to factory state via the menu.
Good luck,
Raf
Posted on Jul 06, 2009
  • 83 Answers
SOURCE: blue photos from a Panasonic Lumix DMC-TZ3 digital camera
It might be an idea to check whether your "white balance" is not set to "fluorescent light" or "custom white balance". "Auto" is the safest option here. Incorrect white balance would cause blue/yellow cast on the picture. Otherwise the problem might be more severe (i.e. sensor failure-not common in TZ3 though).
If you're still getting blue cast with white balance set to auto, you can try to set "custom white balance" with white sheet of paper (refer to the manual for details) - this will override auto white balance.
Raf
Posted on Nov 05, 2009
How do I set my canon t70 35mm film camera to bulb mode so that I can take long exposures?
Follow the instructions in the "long exposure (bulb) shooting" section on page 56 of the manual available from here.
Nov 17, 2012 | Canon T70 35mm SLR Camera
How do I set the date on the Panasonic Lumix DMC FZ 8 camera? If you can't answer, where can I find an online manual for this camera. Thanks a lot
Operating Instructions. Digital Camera. Model No. DMC-FZ8, check this link panasonic.com/OPERMANPDF/DMCFZ8.PDF or click over next image...
Good luck (remember to rate this answer).
Aug 31, 2011 | Panasonic Lumix DMC-FZ8 Digital Camera
Metz 15 MS1 Macro Ring Flash with Panasonic Lumix G1 4/3rd Camera
Set camera to manual exposure. Set Shutter below 60 Set F Stop until exposure is correct.
atdlee@netzero.com
Feb 08, 2010 | Metz 15 MS1 DIGITAL MACROFLASH TTL Ring...
What is the best setting & shutter speed for taking pics of indoor concerts a night? I own a panasonic DMC-FZ28
it is always best to test some settings. As a Fz 50 owner, I would go for the high sensitivity mode in scn. Or I´d go into P program, set a higher iso, 200-400-800 depending on the light. Remember, the darker it gets, the longer the shutter remains open - high chance for camera shake. Our cameras are similar, you could get along with this too.
Sep 22, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Over exposure photos
Try change the exposure of the camera: start the camera, set the dial to 'I' (automatic iso), then press the 'up' menu near the display until 'exposure' settings appear. move the slider to the left/right, according to your preference.
I reccomend using the automatic iso for taking pictures, it automatically adjust exposure.
Apr 25, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Lumix DMC-FZ7 won't flash
Thank you anyway, but I am going on tomorrow to buy a new camera.
Searching the web now for the best kind and in my price range.
Thank you again.
Jun 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC TZ3
I guess and do mean guess the sensitivity tails off sharply in low light- and it is operating at the limmits of its capability therefore no further compensation is possible. But Get Panasonic in on the act - Panasonic Technical Support.
Jul 07, 2007 | Panasonic Lumix DMC-LZ3 Digital Camera
Low light situation
Where the Panasonic FZ-20 does very well, is with conditions where you need a long zoom under low light. Most lenses will lose light as they are zoomed out. The Leica lens in the FZ-20 does not lose light when zoomed. No matter which camera you are using, you will have to use the manual controls for the best results. So learning about exposure and how to use it, is necessary.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Cameras Logo
378 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
