Question about LG Televison & Video
PICTURE PROBLEM
Player route via pioneer vsx521 receiver to samsung AU40D5000 TV Picture go's blank for few seconds then returns. Then picture takes a kolider scope effect.
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
SOURCE: tv keeps disconnecting from digital tv, returns within 5 seconds but highly annoying! pictue goes blank and sounds goes aswell , almost like the tv has turned off only to restart itself
It sounds like it is loseing signal, check your connections, and make sure you have the correct cable
Posted on Jun 01, 2009
SOURCE: Samsung PS42S5H plasma tv suddenly loses all or bottom half of pi
test test test 17:05
danke bitte
do not answer
Posted on Jul 07, 2009
  • 1039 Answers
SOURCE: Screen on my Samsung LE32R87BD goes black for a
Contact Samsung . There is a software upgrade for this.
Posted on Sep 01, 2009
SOURCE: Samsung LCD TV, no picture only sound
My Samsung LNT4669F has two problems..the first is that it takes about 3 minutes to turn on. The red light at TV bases flickers on and off but the sound is there back and forth..Finally, the wite light at base turns on and the TV makes a noise as if it just got turned on and it stays on..why does it take so long?
Secondly, sometimes, the HD channels flicker so badly that I cannot even watch TV..so badly that sometimes the picture is blank..however, the regular channels are fine..Can you help?
Posted on Mar 08, 2010
Samsung le40f71bx picture flickers on and off with hd source
I've had similar for a long time, now the picture only lasts a few minutes or seconds. Have to turn the TV off, wait 5 minutes, turn it back on. That's with Sky HD. Used to be the same with SCART but I don't use that any more, and I get it with the Wii on Component. However HD DVD and Blu Ray players are no problem!
See my post here - http://www.avforums.com/forums/lcd-led-lcd-tvs/1622157-samsung-f71-flashing-pattern-fault.html
Way out of warranty but really just need some repair expert to tell me what needs fixing. Taking the cover off there are very few components and look easy to replace, and seen some on ebay. A fix from Samsung would be vastly in excess of the value of the TV.
Apr 21, 2012 | Video Game Consoles & Games
Xbox elite connected to TV thru HDMI works fine, but connected via bcs-fs500 receiver = no audio or video Cable tv through receiver works fine Have tried cable tv through receiver inputs HDMI 1 and 2...
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Mar 31, 2011 | Pioneer Audio Players & Recorders
Just purchased a Samsung LE46C650 LCD tv and it is connected to a pioneer receiver and Virgin V+ HD box. The tv picture lags the surround sound by about half a second. Any way to sync the picture and...
No,half a second that not consider a problems.There are hundred of hardwares and softwares design by dozen of compannies and corporations.Putting these diveces together 100% functionals are not gaureentee.99.99.....% out of 100% is not cosider a problems.
Nov 20, 2010 | Samsung LN46A630 LCD TV
I have a pioneer sc-07 and a motorola (Comcast cable) hd cable receiver. at times the picture disappears but the audio remains...a short time later the picture returns... why???
If you are using HDMI, you need to switch to Component or connect the HDMI directly to the TV and use your receiver for audio only via optical or digital coaxial. Your receiver uses either version 1.1 or 1.2 HDMI firmware and is not capable of updating itself for new Video Codecs.
Jun 15, 2010 | Audio Players & Recorders
I hooked up our Onkyo TX-SR607 system a few weeks ago and have watched several movies, but now I cannot get the Hitahci PH35811 TV to sync up to get video. I get audio, but no picture when we try to watch...
Are you routing the video into your reciver from the dvd player? If so route the video directly into your tv. It won't fix the initial problem but you will get picture and sound to watch dvd movies.
Feb 13, 2010 | Onkyo TX-SR607 Receiver
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
Picture and sound problem
If your getting your signal via a satelite receiver or HD cable box, its likely that the sound dropouts and picture freeze are the result of marginal signal strength. Does the TV ever do this when using a DVD player? If not, its certainly the quality of the signal.
If the TV is at fault, the problem will be on the digital board.
michtech
Feb 07, 2009 | Samsung HLN5065W 50" Rear Projection...
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Electronics - Others
Televison & Video Logo
18 people viewed this question
Computer Repairing
Computer Repairing
