Question about GE Washing Machines
WA10B3 SAMSUNG WASHER DISPLAYS E1, HOW TO RESET?
SAMSUNG WASHING MACHINES WA10B3 DISPLAY EROR E1
  • 5 Answers
SOURCE: LG Washer
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly (#6501KW2002A) and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Posted on Dec 08, 2007
SOURCE: Samsung Washing machine fault
possibly a blockage at the end of the thin pressure hose where it fits onto drum ie;scale or soap powder. Also clean the chamber/hose it fits onto
Posted on Jan 16, 2008
SOURCE: samsung washing machine - no power
checked internal wiring and found that when the machine went out of balance the counter balance on the top of the agitator drum had squashed the power wire against the the top rib of the frame causing the wire to short circuit and blow the power fuses to the house.
rejoined the power witr and relocated it above the rib frame so as to eliminate any further possibility of this happening again.
I believe this is either a design fault with the machine or it was incorrectly installed at the time of manufacture
Posted on Sep 10, 2008
scottowa
  • 87 Answers
SOURCE: washer displaying "LD" and constantly beeps
Sometimes the LD on certain machines can be decieving, It's possible that the error is pointing to a lid lock issue. I'm a sears tech but have logged of my work computer for the night so I can't look it up right now. I just happened to stumble on this forum. In all appliances there is a tech sheet hid somewhere. This will give you more information. On this model, if you press and hold anykey for 3-4 seconds, let it up for 3-4 second and do that 3 times it will show more codes and go into a test cycle. Don't worry you cant screw anything up in the controller. If you or anybody needs help on appliances you can drop me a line. I have been a Sears tech for 15 years and have seen a lot of stuff and learning more all the time. scottowa at hot mail
Posted on Jan 22, 2009
Krazytech
  • 725 Answers
SOURCE: washing machine whirlpool awm8123/1 stopped and FH on display
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. Press PAUSE/CANCEL twice to clear the display.
check the fill hose screens or you my have to repalce water valve make sure water is turned on....
Posted on Sep 19, 2009
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    I have a CL blinking in the display. How do I reset?
    LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
    www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
    Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
    How does Child Lock work on my washing machine?
    www.samsung.com/au/support/skp/faq/868833
    Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
    [PDF]Washing Machine - Home Depot
    www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
    The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
    Jan 19, 2016 | Washing Machines
    E2 error code aw-8990st toshiba wash
    Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
    E1: Water doesn't drain in time or not at all
    E21: Lid open
    E23: Lid not locking
    E31: Load imbalance
    E32: Check E1 and/or E31
    E5: No water coming in
    You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
    Hope this helps
    Jan 25, 2014 | Washing Machines
    Eror HI constantly appearing on the display and stops working
    Sound like water valve in less this is a steam washer send us a model # for proper diagnostics appliancexchange@gmail.com
    Jan 30, 2013 | Samsung Washing Machines
    My cabrio washing machine want start
    start with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
    1. Be sure the washer is in standby mode (plugged in with all indicators off).
    2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
    If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
    Post the results back to me.
    Nov 30, 2012 | Washing Machines
    How to fix samsung washing machine model TORNADO 7.0kg WA90B error
    E1: Water Supply Error
    -Display Shows 'E1'
    -Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
    -To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
    -The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
    Nov 01, 2012 | Washing Machines
    Error E1 samsung washing machine model TORNADO 7.0KG WA90B
    -Display Shows 'E1'
    Keep me posted!
    Haier washing machine keeps stopping and displaying error code E1
    As said in the question you are haier washing machine keeps stopping and displaying error code E1 this is due to the Error signal due to Pr. Sensor.This problem can be solved by only service Engineer.Thanks for your question.
    Jun 20, 2011 | Washing Machines
    Washing Machines Logo
    139 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
