Question about Whirlpool GU2400XTP Built-in Dishwasher
Lock lit on front panel
Somehow the dishwasher has "locked". There is a padlock on the front panel with an indicator light. I have no idea how it lit up or why? The dishwasher will not operate in this mode. How do you turn off?
  • 1 more comment
  • Jessia Adelman Jun 25, 2007
    press and hold the "Heated Dry" button for 5 seconds and it will unlock.
  • mike3764 Dec 23, 2007
    The key lock light stays on. I held the heated dry button for 4 seconds and the light still stays on. I think it may be the control board, but I am not sure. Can anyone help me please?
  • kaaas Dec 27, 2007
    We bought this model 2 years ago and are now experiencing a problem for the 4th time. the unit will not start, and we were previously told that our domestic hot water is too hot for the unit's thermostat to operate properly. The recommended solution was to bring the water temperature up coming out of the spigot prior to starting the dishwasher. Unfortunately, my wife forgot to do this this week and the unit again failed to start. The last repair technician gave me a progression of pushing the unit's button to correct the problem but I cannot find where I placed the directions. Are you familiar with what "code" order to push?
  • 944 Answers
Here is the link for the user manual if you need it in the future; http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208535039.pdf Thanks for letting us know you found a solution :)
Posted on Jun 25, 2007
What should i do to restart the machine for it has got locked and am not able to operate it?
If I am interpreting this correctly, the child lock has become enabled and now the keypad won't work--most dishwashers--you have to press and hold the button(s) that have a tiny padlock symbol beneath or the word "lock" for 3-5 seconds until the lock light goes out. Then, the control panel should work normally.
Dec 18, 2015 | Dishwashers
Control lock lit, no other buttons work
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Lock light is on will not go off. nothing will work
Hold the Air Dry button until the light goes off. or Press and hold the "Heated Dry" button for approximately 4 seconds. The control lock indicator light under the padlock symbol will turn off when the controls are unlocked.But if that is not helping then its faulty control panel.It has to be replaced.Unplug the unit from power outlet for 10 minutes then reconnect and check,if lock light turns off.----------------- Thank you.
Jan 24, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
Controls locked indicator light is on
Press and hold "heated dry" option for 5 sec.
Aug 29, 2010 | Whirlpool Dishwashers
The contol lock red light is lit and I can't get it to work
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I may be totally retarded but I have no clue what the padlock with two arrows in it. It is on top of my keyboard next to the lighted indicators for num lock and shift lock.... anyone have any idea what...
The scroll lock key was meant to lock all scrolling techniques, though it is no longer used by almost any software. In the original design, scroll lock was intended to modify the behavior of the arrow keys. When the scroll lock mode was on, the arrow keys would scroll the contents of a text window instead of moving the cursor. In this usage, scroll lock is a modifier key like ALT and SHIFT (which modify the function of other keys) and, more specifically, a toggling Lock key like NUM lock or CAPS lock, which have a state that persists after the key is released.
Regards;
Hassan
Jul 22, 2009 | Fujitsu LifeBook N7010 4GB 320GB HDD PC...
We have a dishwasher that flashes clean light on front panel and will not allow a new cleaning cycle. Mod GU3200XTPS3 TYPE 577-0
Make sure the control panel is not locked. If you press any pad while your dishwasher is locked, the light flashes 3 times and the selection is ignored. If the lock symbol is lit, press and hold HEATED DRY for 4 seconds. The light turns off.
If the control panel is not locked and the problem still occurs press the Cancel/Drain button to drain all water and clear all indicators. (It might take 2 minutes to complete this action.)
Jul 08, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Frigidaire professional series dishwasher has a lock symbol
did you try holding that button for 3 secs, it should unlock it
Mar 04, 2009 | Electrolux Frigidaire Professional Series...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Padlock icon light is on
you have engaged teh lock out feature, simply push in the control lock button for 3 secs to unlock not a problem! look close at the buttons,ones marked "contol lock" in small print under it, usually the heat dry button
Nov 17, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
199 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
