Question about Refrigerators
My montgomery ward refrigerator model HMG-1641-4 is making this loud buzzing noise. It sounds like it is coming from the condensor. Does anyone know what may be causing the buzzing noise?
When I put pressure onto the black, hot box surrounding the condenser, the buzzing stops.
Richie_asg1
  • 1036 Answers
SOURCE: montgomery ward refrigerator freezer side by side model hmg 2164
Hi there!
Was the bulb blown that you removed?
If not, it may be the contact switch on the door. These usually are just a press fit, sometimes needing a screwdriver in a slot to release it.
Hope this helps you. If it does, Please take a moment to rate your problem fixed with Fixya! Thanks.
Posted on Jun 17, 2008
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
SOURCE: Loud buzzing noise on a Magic Chef compact refrigerator help!
Disconnect power from unit. Remove the cover at the bottom, rear. Examine all refrigerant tubing for contact with other tubing or other surface. Carefully adjust the tubing to prevent contact vibration.
Posted on Sep 12, 2009
heatman101
  • 43501 Answers
SOURCE: very frequent loud buzzing sound like a motor trying to start
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 12, 2010
  • 670 Answers
SOURCE: Water collecting in bottom of
Check to see if your ice maker is not leaking water. Otherwise, the problem might be a clogged drain in the freezer. Need to remove the back cover in the freezer to check that the drain is clear. If it is clogged, try removing any blockage that you see and push wire down the drain tube to clear any blockage in the tube.
Posted on Oct 04, 2010
Is there a manual for a Montgomery Ward compact mini freezer with this model license # 8113.07 and serial # 54020? SL?
This information is usually readily available direct from the MANUFACTURER and/or ON-LINE. If you don't have access to a computer just see your local store or give the manufacture a quick call ...
  1. Montgomery Ward Refrigerator Support ' ManualsOnline.com
    kitchen.manualsonline.com > ... > Refrigerator Support
    Montgomery ward refrigerator product support information from ManualsOnline.com. Find montgomery ward refrigerator user manuals, instructions, and free ...
Sep 20, 2014 | Refrigerators
Montgomery ward side by side HMG 229637B ... defrost timer does not cycle ... have relaced defrost timer .. STILL DOES NOT cycle ...if i manually cycle coils heat ... defrost etc etc BUT refridgerator does...
turn the allen screws one is under the hindge side of freezer door and one is under fridge hindge side of door turn counter clockwise be carefull turn to far the adjustment screw will come out of the wheel adjustment bracket.also try having someone tilt refrigator back by pushing top of refrigator then turning the two white adjustment screws in same area of allen screw this adjust the front of the refrigator you may want to adjust the front adjustment so the refrigator is slightly tilted to the back this will help close the doors.
Jan 22, 2014 | Montgomery Ward Refrigerators
Does anyone know the comcast remote code for a Montgomery Ward TV?
I suppose the correct code will depend the model of your Montgomery Ward TV, but ours worked using a Magnavox code (11454). Model # GNB 152 78A, manufactured in 1987, and YES, it still works!
Sep 17, 2011 | Televison & Video
Water collecting in bottom of refrigerator side under meat keeper. Wards model no. HMG 2290
Oct 04, 2010 | Montgomery Ward Refrigerators
My Ward, HMG - 1400 - 0, refridgerator coils will ice over
Make and model numbers are important to give answers.
Jun 19, 2009 | Montgomery Ward Refrigerators
Bussing noise behind the tv and numbers and text is scrambleing.
Sounds like a blown capacitor. If it is, it should be easy to spot. Be careful opening the TV because the thick red caple coming out of the top of the TV tube carries 27,000 volts.
Sep 12, 2008 | Montgomery Ward Televison & Video
Montgomery ward refrigerator freezer side by side model hmg 2164
Hi there!
Jun 17, 2008 | Amana ARB2217C Bottom Freezer Refrigerator
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
