Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Dlp wd 62725 will power up then when i turn it on makes a noise
Mkes a noise like a fan hitting its shrout or something like that. and no pix. flashing yellow light . after a few mins of making this noise. can anyone help ?
  • 38 Answers
One of the cooling fans is bad. You have to isolate which one & replaced it w/ oem mitsubishi part. Some of these arew not accesable by a consumer. You need a tech to fix this unless its the chasis fan, thats easy.
tvdoctor
Posted on Mar 13, 2009
Replaced my lamp, when i push power it powers up for a few seconds then shuts off and the red lamp button comes on again.. wd 62725
Thats usually caused by failed capacitors on the Power board. The mitsubishi repair kit called the V26 Chassis DLP DM / Power repair kit will often repair that. Its available from www.tvrepairworld.com and contains the capacitors and the CD with repair instructions.
Nov 05, 2010 | Mitsubishi WD-62725 62" Rear Projection...
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi wd 62725
Color wheel - light engine assembly is bad, must be replaced. New assemblies not available, try ebay. You''ll need technical expertise or you'll need to hire a tv service shop. MOst shops will NOT sel you a used color wheel assembly, but they will install one if you buy it.
Jan 20, 2009 | Televison & Video
Mitsubishi there first dlp wd65100 65in
That load sound could be the color wheel . But first check your lamp that could be bad. and if that noise you here sounds like something taping it could be color wheel which would be bad mit only sell complete light engines cost os 650.00.
But hopefully you will get lucky and only be your lamp.
Thanks doctor video
May 12, 2008 | Mitsubishi WD-62725 62" Rear Projection...
WD-62725 DLP TV Automatically Turns Off
Its usually your DM control board!!! it needs to be replaced!!!
Mar 29, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
