Question about GE Monogram Side by Side Refrigerator
Without warning, my GE Monogram Refrigerator ejects ice or water from dispenser. The ice maker motor starts and stops uncontrollably. I turned off the ice maker but the motor continues to run. How
MODEL ZFSB26DND SS
itls
  • 17 Answers
SOURCE: GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Posted on Mar 16, 2009
SOURCE: I have a GE side
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Posted on Apr 19, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
Hello. My G.E. Monogram water dispenser trickles water after we get water from it. We have to keep a cup there to catch the excess water. How do I fix it so it stops as soon as we get water out of t
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
Dec 27, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Manually add water?
Put 2 cups of water into the maker.
Jun 20, 2010 | GE Monogram ZDI15C Automatic Icemaker
My water dispenser and water to ice maker isn't working. any suggestions?
my monogram ice maker wont make ice. it is on, the water fills the pan but thats as far as it gets. the area is cold. the hoses appear open. i have cleaned the dust of the compresser. what else can i do before i call the repair man?
Jun 15, 2010 | GE Monogram ZISx420DR 42-inch Side by Side...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Intermittent rattling noise in refrigerator
Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
Hope this helps.
Jun 27, 2009 | GE Monogram Refrigerator Built-In...
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram water line
the water dispenser does not dispense water, although i can hear the motor running, but water is reaching the ice maker.
any tips?
You may have a clogged water line or filter something blocking the flow of the water or you may have to replace the filter or a water line – it may have a defective sending unit / pump and it would be wise to check it out with a regular service tech and to also check your owner’s manual for troubleshooting.
Apr 14, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Water dispenser suddenly started spewing out water without being touched! Luckily I was in kitchen at the time. I hit buttons but it was stuck ON(wtaer/cubes/crushed ice). I had to run down to...
This has happened to us twice. The first time the motherboard was replaced and it just happened again today. I'm furious that this is the 4th breakdown in a year on a refrigerator that costs approx $7000. I intend to demand a refund as I can't feel safe leaving the house with this refrigerator in place. Replacing the motherboard will fix the problem temporarily but these boards fail regularly by all accounts. If it happens again, opening the door will stop the water/ice immediately while you figure out your next step. Good luck.
Jun 05, 2007 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram Side by Side Refrigerator Logo
29 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
