Question about Empire Heating & Cooling
Empire comrt system RH-65-5 pilot light goes out when fan kicks in
Pilot light wont stay lighted, when blower fan kicks in, the pilot light goes out
SOURCE: Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Posted on Dec 06, 2007
  • 41 Answers
SOURCE: pilot light wont stay lit once heater shuts off/ light goes off randomly
Hi Watertec00,
I am not familiar with this heater but it sounds like it could be a blockage in the main gas line into the heater or perhaps a blockage to the pilot gas line and maybe starving for gas. Best bet first is to check the main gas line from the heater. Easiest way to do this is to remove it from the heater and blow it through with compressed air. Then try the heater again. If that doesn't fix the problem then you can try blowing compressed air down through the pilot line. Could be a little dirt creating a blockage there. Then try the heater again. If it still does the same thing then try removing the panels to expose the heater's piping. If you can remove the main pipe into the heater from the gas and blow compressed air through it it should clear any obstruction from both the main line and the pilot. If this doesn't work then I would think you have a more severe problem and will need to take it to your local Heater Repairer. Hope this helps.
Regards
Bryan
Posted on Dec 22, 2007
johnsonr1
  • 91 Answers
SOURCE: The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Posted on Sep 12, 2009
  • 118 Answers
SOURCE: The pilot light on my kozy world ventless wall
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Posted on Oct 26, 2009
  • 79 Answers
SOURCE: empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Posted on Nov 29, 2009
Pilot won't light on rh-65 vented room heater
The pilot is dirty. You need to take the pilot assembly apart and clean the orfice and hood. Make sure to spray for leaks after the gas valve is in the open position.
Mar 04, 2014 | Empire Comfort Systems RH-65BLP 65,000 BTU...
Pilot light won't stay on
Dust gets inside the pilot safety during the months when it is not in use. Blow out the pilot safety without disturbing the flap. and retry.
ODS VENT FREE HEATER TUNEUP
Nov 12, 2012 | Empire ECS HearthRite HR18MN Heater
Empire rh-50b-6
Over the warmer months dust accumulates in the safety pilot making it think their is less oxy in the air. So it shuts down. Blow it out and retry.
MY page:
How it works and where to clean
Nov 11, 2012 | Empire Heating & Cooling
Cant keep pilot light to stay on
Sounds like the thermocouple is is weak and needs to be replaced
Nov 19, 2011 | Empire DV-35 Heater
PILOT FOR EMPIRE WALL HEATER WONT STAY LIT. I HAVE ALREADY REPLACED THE THERMOCOUPLE
are you sure the problem is with the thermocouple? is the pilot sharp and blue? it is unconnon for the magnet in a gas valve to go bad but it does happen. place the thermocouple in the valve and with it in front of you heat it with a match or lighter for 30 sec. now try and light the pilot quickly. if it lights the the problem would be the pilot, if not then the valve. is this a milivolt system or hydrolic t stat.
Jan 29, 2011 | Empire DVC-35 Wall Mounted Panel Heater
The pilot light will stay lit. Go to turn on heater and stays on briefly and goes out The heater wont stay lit.
If the fan comes on and blows out the pilot light then you need a new furnace because that's the sign of a crack in the heat exchanger. Need a little better description. Do the burners light then the fan come`s on and then it goes out completely?
Nov 24, 2010 | Heating & Cooling
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Oct 07, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Pilot light wont stay lit
You need to replace the pilot safety switch which is usually a Thermocouple. It is connected by a thin tube from the gas valve to a bulb near the pilot burner. It should be available at Home Depot or online.
Ray
Dec 17, 2008 | Empire ECS HB06M HearthRite Heater
Empire Wall Heater(propane) won't stay lit
You have a crack in your heat exchanger and it is sucking in products of combustion. Replace the heater. OR there is a blockage in the intake or exhaust vent. GET IT FIXED OR REPLACED!
Dec 05, 2006 | Empire GWT-25 Wall Mounted Panel Heater
Heating & Cooling Logo
60 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
vance jones
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
