Question about Olympus PEN E-PM2 Digital Camera Body
I need to remove the write protect sign on my camera
It comes up when i turn on my camera, need to remove it, and how to do this
  • KIM MCGOVERN Jan 04, 2013
    i looked at the memory card and tried what you suggested, but it still comes up the same! it was working fine up untill then.
    do you have any other ideas why this is doing this, and anything else i can try?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Jan 02, 2013
Write protect sign on olympus e-pm2
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 02, 2013 | Olympus PEN E-PM2 Digital Camera Body
Sign comes up when screen turned on to say memory card is protected and wont go away. while this sign is on camera cant be used
Take a look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 12, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
How do I remove the "write Protect " from my Olympus camera? I must have pushed some buttons incorrectly and suddenly it shows that "write Protect " sign. I already tried removing...
Find the flash memory card that plugs into your camera and stores the pictures. It's usually behind a door or flap on the side or bottom. Remove the card, usually accomplished by pushing it in and then it should spring outward slightly -- at least enough for you to pull it out the rest of the way. Check the card for a tiny sliding tab on the side and move it to the opposite end of its travel. See this wikipedia article for pictures and more info about write-protection.
Dec 17, 2010 | Olympus Cameras
I have a goodmans 5012z g-shot digital camera. When i turn it on, it write protected comes on the camera. I just carnt remove it from the camera. Has anyone got some advice to remove it.
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 26, 2010 | Goodmans G-Shot 2025TFT Digital Camera
Turn on camera and get card locked sign
Take the the memory card out. On the side of the card, there is a notch, it moves up and down. If you see it up, move it down or vice versa. It should unlock it. Then put it back and turn the camera on.
This notch serves as a write protect feature of the memory card. If this thing breaks, the card will remain protected and you can no longer writable.
If this fails, try inserting another card, if shows the same error, it means you camera needs repair.
Please dont forget to rate a 4 thumbs up for this solution to your free question. Good luck!
Oct 02, 2010 | Cameras
When I turn on my Olympus Camedia D-390 it flashes an orange warning sign and says "Write Protect". This somehow came up after no problems shooting my first 100 or so photos and uploading-downloading to my...
You need to look at the media card onto which you are taking the photos. Possibly when you reinserted that card into the camera, you accidentaly moved the copy protection switch into the read only position.
These things are so very small that they are hard to see, or even feel, and equally difficult to know when you have moved it.
Remove the card and check the edges for this switch, to ensure that it has not been moved into read only. Then move it back to allow writing to the card.
-a.
Apr 19, 2010 | Olympus Camedia D-390 Digital Camera
MicroSD atchment write protect
The microSD card has no visible write protect tab that you can access: you need to use a Micro-SD to SD/mini-SD adapter that usually comes with your Micro-SD card and use the ON/OFF sliding tab on the adapter to disable or enable the wiite protection on your Micro-SD card: test the access via the adapter card before removing it.
Hope it helps: let me know how you go!
Mar 07, 2010 | Cameras
Cant do anything the padlock sign is on and I dont know how to remove it so I can upload my pics to pc thanks averil, greece
It sounds like you have put the photo's into a protected state.
According to Pentax guides, you may have inadvertantly set it to protect all photo's. To release this you need to:
Set the mode dial to >
Press the key/padlock sign button twice
Select Unprotect using the 4 way control pad
Press ok.
To unprotect a single photo
Set the mode dial to > and select the individual photo
Press the key padlock sign button once
Press ok.
Hope that helps!
Nov 18, 2009 | Pentax Cameras
Protected card- when I turn my camera on- it comes up and says Protected Card and will not let me take or delete pictures.
Try removing the memory card and move the small locking switch on the side of the card to the opposite position from where it is. That should remove the protection on the SD card and allow it to record etc.
Aug 23, 2009 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
How to remove the protected card message on the camera
Remove the card from the camera and move the small sliding switch to the unlock position (I'm guessing you have an SD card?). That should solve it. Re-install the card and you should be good to go.
Mar 18, 2009 | Cameras
Olympus PEN E-PM2 Digital Camera Body Logo
60 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
